> Bulkhead 6 Motor Mount!, Update to Brakes Pressure Regulator! Now W/bulkhead photos!
Jeffs9146
post Feb 28 2011, 06:26 PM
Ski Bum
OK I got my Maddog mount and it looks like I am still having to do more than just weld it in!
What did you guys do with the Brake Proportioning Valve? Also, how high do I mount this? It looks like it will have to be high to clear the heater pulls?
Eric_Shea
post Feb 28 2011, 08:12 PM
PMB Performance
I'm going with a bias adjuster somewhere in the cabin.
This isn't about bias on a 914. It's about saftey. That valve has nothing to do with bias.
A mid engine car has polar moment inertia (think spinning top). It's tough to get it to spin but, when it does... you're screwed. This valve prevents your rears from locking, causing spin in a panic stop.
A "Bias Valve" can only "restrict" fluid movement to the rears (you can't really hook it up backward). (IMG:style_emoticons/default/blink.gif) Our rear brakes are small (matched perfectly to the fronts by those dumb guys at the Porsche factory). You want your rears working 100%... 99.9% of the time. The only time you don't want them working is in a panic stop. This is when your pressure regulator kicks in.
Another way to look at it is: 70 + 30 = 100%
Now... add a bias control valve and give it a turn: 70 + 20 = 90% Give it another turn: 70 + 10 = 80%
I'd rather have 100% of my brakes being used when I come into a corner. Especially these brakes. Just say'n. (IMG:style_emoticons/default/biggrin.gif)
Jeffs9146   Bulkhead 6 Motor Mount!   Feb 28 2011, 06:26 PM
McMark   70-74 cars have the P-valve mounted on this rib.   Feb 28 2011, 06:30 PM
Jeffs9146   So what should I do for my 75? :idea: Maddog adve...   Feb 28 2011, 06:35 PM
MDG   So what should I do for my 75? :idea: Maddog adv...   Feb 28 2011, 06:54 PM
SLITS   Depending upon what you are going to run .... Car...   Feb 28 2011, 06:39 PM
sww914   I'm already dead once from that. I was a nice ...   Feb 28 2011, 06:45 PM
Jeffs9146   7" would put the lower part of the mount be...   Feb 28 2011, 06:51 PM
SLITS   7" would put the lower part of the mount b...   Feb 28 2011, 07:09 PM
kconway   I'm doing this too. Eric sent me these for pl...   Feb 28 2011, 07:01 PM
9146986   K. Conway has a Rich Johnson mount, not Maddog.   Feb 28 2011, 07:24 PM
kconway   K. Conway has a Rich Johnson mount, not Maddog. ...   Feb 28 2011, 07:41 PM
MikeSpraggi   I don't have a Maddog mount and I am running a...   Feb 28 2011, 07:54 PM
Eric_Shea   They are basically. All copies of the Vellious ...   Feb 28 2011, 07:58 PM
Jeffs9146   Lennie and I just decided that we have everyth...   Feb 28 2011, 08:09 PM
Eric_Shea   This isn't about bias on a 914. It's ab...   Feb 28 2011, 08:12 PM
Eric_Shea   Mock install the lines and let them be your guid...   Feb 28 2011, 08:14 PM
Lennies914   Mock install the lines and let them be your gui...   Feb 28 2011, 08:24 PM
Jeffs9146   Mock install the lines and let them be your gu...   Feb 28 2011, 08:31 PM
Jeffs9146   Thanks Eric! :asskiss: :DRUNK: I ment t...   Feb 28 2011, 08:17 PM
Eric_Shea   Hmmmmmmmm... hard to say with that one. As you ...   Feb 28 2011, 08:21 PM
SLITS   I've had both the RJ and the Maddog .... nothi...   Feb 28 2011, 08:42 PM
John   I made my own bulkhead mount. It's easy espec...   Feb 28 2011, 09:54 PM
John   more   Feb 28 2011, 09:56 PM
Jeffs9146   Interesting!! I guess I could cut the Mad...   Feb 28 2011, 11:15 PM
John   Interesting!! I guess I could cut the Ma...   Feb 28 2011, 11:39 PM
McMark   If you wanna move your P-valve, I'm happy to p...   Feb 28 2011, 11:19 PM
Jeffs9146   If you wanna move your P-valve, I'm happy to ...   Feb 28 2011, 11:50 PM
maddog   Jeff, You are correct, you will have to re-locate...   Mar 1 2011, 06:08 AM
McMark   The top mounting hole is about 1.5" down from...   Mar 1 2011, 11:05 AM
Jeffs9146   The top mounting hole is about 1.5" down fro...   Mar 1 2011, 11:41 AM
McMark   ;)   Mar 1 2011, 11:57 AM
Eric_Shea   Dave, for your documentaion, a lot of 74 cars have...   Mar 1 2011, 04:22 PM
Jeffs9146   After spending some time test fitting and cutting ...   Mar 1 2011, 09:15 PM
Jeffs9146   Here is a914guys for comparison! Maddogs woul...   Mar 1 2011, 09:23 PM
Jeffs9146   Well, here it is installed with the first coat of ...   Mar 4 2011, 10:58 AM
Jeffs9146   Todays progress! I have now installed the ear...   Mar 7 2011, 08:07 PM
Lennies914   Damn Jeff, You sure get alot done when I'm not...   Mar 7 2011, 08:50 PM
kconway   Can anybody provide the dimension from the top of ...   Mar 7 2011, 09:58 PM
moparrob   Can anybody provide the dimension from the top of...   Mar 7 2011, 10:42 PM
kconway   Can anybody provide the dimension from the top o...   Mar 7 2011, 11:09 PM
Jeffs9146   Everyone told me to mount it 7" from the bott...   Mar 7 2011, 10:10 PM
Jeffs9146   I know, I had to trust those who posted the 7...   Mar 7 2011, 11:35 PM
RiqueMar   I know, I had to trust those who posted the 7...   Mar 16 2011, 07:51 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:20 AM
