My Six Conversion - School Bus Yellow, 1st time conversion project for me |
MikeSpraggi |
May 20 2009, 11:59 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
So I find this '70 914 on Craigslist for $700. Says it's only a shell. Has flares and 5 bolt 911 pattern on all 4 wheels. I call, make an appointment for 2 days later. Car looks like it has good bones. I asked "what happened to the engine and trans?" The guy says, "Oh, it runs". So I buy it. It's going to be my DE/track car. That was THREE years ago. So to get the original six off the track, I started to "put" the project together.
I had been collecting parts for a six conversion for about 10 years or so. I have just about everything I need, but, this is a LOT of work and a LOT of $$$ if you add it all up. Wife keeps asking, when is it going to be finished ............. (IMG:style_emoticons/default/lol-2.gif) Here are some pics. As seen on Craigslist in Philly in Feb of 2006. FG bumpers did not come with the car, but a 1.7L engine did. 2 years later after I bought the FG hood and trunk and replica Fuchs |
ChrisFoley |
Mar 6 2011, 04:06 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Looks good Mike!
One suggestion I have though, is to ditch the bolt-in front sway bar reinforcements. Get weld-in ones and do it right, or eventually the inner fender will crack around the mounts. Also, if its a track car, why does it have a parking brake? That's added unsprung weight you don't need on the rear suspension. |
MikeSpraggi |
Mar 6 2011, 10:24 AM
Looks good Mike! One suggestion I have though, is to ditch the bolt-in front sway bar reinforcements. Get weld-in ones and do it right, or eventually the inner fender will crack around the mounts. Also, if its a track car, why does it have a parking brake? That's added unsprung weight you don't need on the rear suspension. Chris, this is straight from the Vintage Racer Group (VRG) rules: "3.2.8.1. Dual braking systems are required. This may be accomplished with dual master cylinders, a tandem master cylinder, or a single master cylinder plus mechanical emergency brake." Car is sort of stock and when I ditched the original rear calipers and went with the 911 SC rears, the 911 mechanical e-brake was substituted for the original. I would like to install one of the other two options for next season, but don't really have a clue about which way to go. Most installations on 914s I've seen have been fairly custom jobs. I need to get educated before making that decision. Thanks for the tip on the weld-in anti-sway bar reinforcements. |
Lo-Fi Version | Time is now: 31st May 2024 - 10:46 PM |
