My car refuses to shift into 2 gear, I have no clue were to start |
weird_looking_cactus |
Mar 19 2004, 10:18 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
When I had the car running and was able to drive it the car, it would not shift into second gear. It had a pushing filling on it when I would try to go into that gear. Also even though I have the clutch all the way in and changing gears like from reverse to first it would make a big grinding noise but only once in a while. So Im thinking I need to tighten my cable to stop the grinding noise. But I have no clue about how to fix second gear. My car is a 1975 2.0 with side shifter. Thanks for those who help.
rhodyguy |
Apr 3 2004, 04:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
heat up the firewall busing in hot water and it will go in much easier. for a side shifter there is: front to back, 1. 2 round bushings inside the shiftl ever assem, 2. 1 round at the firewall, 3. 1 round on the shift rod support housing on the trans, 4. 1 ball cup bushing for the shift selector on the trans. there are 2 coupler bushings at the connection point for the f &r shift rods. see what mike says before you order any thing else.
kevin |
Lo-Fi Version | Time is now: 8th June 2024 - 10:19 AM |
