> Engine, What do guys think of this engine?
Ray Warren
post Apr 2 2004, 07:16 PM
What do you guys think of this engine?
Does it compare to the engine a couple
of threads down?
Less than 1000km, currently in car, can be heard and driven.
2056cc T4, based on original 914 2.0 engine (GA case, correct heads, windage tray)
9.5:1 CR
All rotating parts precision balanced
new NPR 96mm pistons, rings, and liners.
Big valves, ported, incl new valves, valve guides, new HS springs from FAT performance. Heads flycut, chambers cc'd
all new std bearings (crank not ground)
rods resized and bushed, new rod nuts
new 911 clutch, rebuilt PP, newly resurfaced flywheel. Again all balanced as a unit with crank and other rotating bits
genuine OE porsche 911 'elephant foot' valve adjusters
new FAT performance HD rocker studs.
new FAT performance street cam - .495" 290 deg, new cam gear of course, new lifters
new FAT blueprinted oil pump
New Eurorace shorty intake manifolds, match-ported for DCNFs and T4 head.
Stainless steel heat exchangers
new Mallory distributor and new mallory Hyfire 6 AL ignition (price those up....)
completely rebuilt Weber 42DCNFs
New K&N filters
fancy Accell sparkplug wires
Blasted and repainted tin, new hoses , etc, etc, etc...
Ray Warren
post Apr 3 2004, 05:57 PM
Mark you might know this engine.
I think Mike worked on the car.
It looks like Mikes shop in the background.
- Lo-Fi Version Time is now: 13th November 2026 - 10:44 AM
