> V8 Conversion Kits, Kits, parts which is the best
914gem
post Apr 3 2004, 09:51 PM
All you V8 guys and guys that have built these pocket rockets which kit or combination of parts work best. Such as quality of parts, service, instructions, cost,ect. How about some testimonys and storys from V8 people about their cars, what they used and what they wouldn't use if they had it to do over again.
chunger
post Apr 3 2004, 11:52 PM
Get the Renegade radiator setup. It's worth the money.
Never heard any complaints about KEP's adapter and clutch components. They're good folks who know what they're doing. Parts are top notch
Stay far away from Red Dawg
Renegade Hybrids provides very good customer service and their kit components work well. They go out of their way to make you happy and make sure things are right. They're the only people presently updating the kit, testing, and trying to bring new conversion products to the market. . .well, at least of the major conversion guys.
Rod Simpson's the original kit guy. . . he's been selling the same parts and will continue selling the same parts. No updates in quite some time. Radiator setup is not bullet-proof. . . some have experienced serious problems with it.
If you're in the Bay Area, consider talking with Brad Roberts now with High Performance House. He's probably put together as many conversion cars w/ varied components as anybody out there.
plan on babying the stock trans AND breaking a few if you go that route. .. or, you can $tep up to the modified 930 or G50 gearbox. I got mine from Renegade and they do good work. . . but, if I were to do it again, I'd talk with Brad first. He appearantly might have a new method of machining the 930 box for our applications and has a source or a plan for custom R&P for G50 gearbox. If you plan to step up, budget in $5000 to do just the gearbox upgrade. . . no joke. That's what it costs (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Biggest problem right now for the upgraded trans is shifting it. It's either an elaborate custom tail-shifter setup or a cable shifter available from numerous sources. Renegade's cable clutch setup for the 930 is pretty slick utilizing the stock omega helper spring. My wife was able to easily work it w/ a 3200 lb. pressure plate. Other option is fab a hydraulic system to get your mechanical advantage.
Skip the 915. It's not as strong and not geared right for the V8 even though it's easier to reverse and Velios has a sideshift kit for it. Brad's pressuring them to do the same for the 930 box.
Pre-86 carburetted Small Block Chevy's fit. LT1's do not because of the front air intake. LS1's are in the works but there are no kits presently available for them. You'll have to fab a little. The actual engine adapters are available though. Appearantly you can reverse the intake on the LS1's to suck in from the back instead of the front. (IMG:style_emoticons/default/aktion035.gif)
I'm piecing together a MPFI system on a pre-86 SBC from mostly Holley parts from their Commander 950 system which also (IMG:style_emoticons/default/aktion035.gif) 's. Using a Megasquirt homespun engine computer. Found it on Ebay. Don't think I'll regret it.
All the other chassis and brake mods are all over the forum. Pick your flavah. .. if you're building huge HP, don't forget huge brakes are not overkill.
-'Chung
914gem   V8 Conversion Kits   Apr 3 2004, 09:51 PM
chunger   Get the Renegade radiator setup. It's worth t...   Apr 3 2004, 11:52 PM
John2kx     Apr 4 2004, 06:20 AM
FriarJohn   In addition to asking Brad specifically and this B...   Apr 5 2004, 10:51 PM
Brad Roberts   Watcha thinking about 914GEM ?? I know you have ac...   Apr 5 2004, 11:37 PM
neo914-6   I tried to build a Jaide (who) kit in the 80's...   Apr 6 2004, 01:23 AM
914gem   Hi Brad, not up to to much. I have a KEP adapter a...   Apr 6 2004, 07:20 AM
Brad Roberts   Renegade all the way. No questions. Hopefully you...   Apr 6 2004, 09:53 AM
boxstr   914GEM here is a 327 with a 283 crank brings it do...   Apr 6 2004, 10:30 AM
turbo914v8   Hi all I used the old Renegade kit from the 90...   Apr 6 2004, 12:17 PM
914gem   Hi Boxstr, your engine compartment looks nice, whe...   Apr 6 2004, 12:22 PM
JmuRiz   That 305 looks pretty cool. I've always loved...   Apr 6 2004, 12:24 PM
chunger   Turbo914v8, Do you have pics? -'Chung   Apr 6 2004, 03:28 PM
Brad Roberts   Talk to us Turbo.. show us some pics.. I knew you ...   Apr 6 2004, 04:48 PM
neo914-6   Yeah Paul G, pics of your beast would be NICE. Ch...   Apr 6 2004, 06:28 PM
boxstr   914GEM thanks the pics are taken before I got the ...   Apr 6 2004, 07:32 PM
turbo914v8   I have been in contact with both Chris and Harry r...   Apr 7 2004, 09:31 AM
soloracer   Welcome Turbo914V8! That is a ton of power to...   Apr 7 2004, 11:43 AM
turbo914v8   soloracer, I took many hours and seam welded the ...   Apr 7 2004, 01:10 PM
Brad Roberts   Hey Paul, Nothing larger than a 930 CV will fit i...   Apr 7 2004, 02:06 PM
turbo914v8   Brad, Thanks for the information. I guess the obv...   Apr 7 2004, 06:26 PM
chunger   Hello, Is there a difference between 930 CV's...   Apr 7 2004, 11:24 PM
Brad Roberts   Chung, Call them and find out what the "kit" incl...   Apr 8 2004, 12:28 AM
Brad Roberts   Paul, I dont actually have a conversion car. Ever...   Apr 8 2004, 12:31 AM
chunger   Do the 911 CV's hold together ok with the 2 pi...   Apr 8 2004, 12:39 AM
Brad Roberts   The holes for the pins are too big to be tapped. T...   Apr 8 2004, 12:46 AM
chunger   Uh oh, Which part of the flanges do not fit right...   Apr 8 2004, 01:00 AM
andys   Brad, Are the 930 CV's the same size as the l...   Apr 8 2004, 09:53 AM
turbo914v8   Brad, Your work must be really grand if you are s...   Apr 8 2004, 10:26 AM
Chris914n6   Hi Chung, glad you made it here. I found a relati...   Apr 10 2004, 01:04 AM
jridder   >Billet water pump housing anyone Cool. Of cours...   Apr 11 2004, 12:00 AM
neo914-6   Seems to me if you have a clean sheet, engineering...   Apr 11 2004, 02:00 AM
John2kx   For comparison, this is the Renegade pump. I pref...   Apr 11 2004, 04:45 AM
John2kx   hikgf   Apr 11 2004, 04:48 AM
John2kx   The fixed inlet fitting on Dessert pump will more ...   Apr 11 2004, 05:01 AM
BIGKAT_83   Davids(Desert Hybrids) steel pump housing lines up...   Apr 11 2004, 06:45 AM
John2kx   Bob, The inlet fittings do appear to work when pu...   Apr 11 2004, 07:28 AM
John2kx   Looking at the RH pump again and comparing to Dese...   Apr 11 2004, 08:09 AM
John2kx   Renegade now offers this piece to aid in eliminati...   Apr 11 2004, 08:21 AM
BIGKAT_83   I used a molded rubber hose with a 90 bend it it f...   Apr 11 2004, 08:54 AM
turbo914v8   Some really great ideas in regards to fixing the p...   Apr 11 2004, 10:20 AM
Brad Roberts   I have access to the small bead roll device needed...   Apr 11 2004, 10:49 AM
Mike T     Apr 11 2004, 11:54 AM
turbo914v8   Brad, As I understand it, RH is instructing peopl...   Apr 11 2004, 07:14 PM
boxstr   John Thomas had posted athread about the thermosta...   Apr 11 2004, 07:20 PM
John2kx
- Lo-Fi Version Time is now: 2nd April 2026 - 12:55 PM
