| Ray Warren |
Apr 2 2004, 07:16 PM
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
What do you guys think of this engine?
Does it compare to the engine a couple of threads down? Less than 1000km, currently in car, can be heard and driven. 2056cc T4, based on original 914 2.0 engine (GA case, correct heads, windage tray) 9.5:1 CR All rotating parts precision balanced new NPR 96mm pistons, rings, and liners. Big valves, ported, incl new valves, valve guides, new HS springs from FAT performance. Heads flycut, chambers cc'd all new std bearings (crank not ground) rods resized and bushed, new rod nuts new 911 clutch, rebuilt PP, newly resurfaced flywheel. Again all balanced as a unit with crank and other rotating bits genuine OE porsche 911 'elephant foot' valve adjusters new FAT performance HD rocker studs. new FAT performance street cam - .495" 290 deg, new cam gear of course, new lifters new FAT blueprinted oil pump New Eurorace shorty intake manifolds, match-ported for DCNFs and T4 head. Stainless steel heat exchangers new Mallory distributor and new mallory Hyfire 6 AL ignition (price those up....) completely rebuilt Weber 42DCNFs New K&N filters fancy Accell sparkplug wires Blasted and repainted tin, new hoses , etc, etc, etc... |
| Mark Henry |
Apr 4 2004, 07:52 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Yep, I've driven it! It's Dave Syer's engine.
Good engine, about as fast as my squareback, so it's around 120hp. Mileage would be correct as Mike just finished the resto on it last June/July. That's Mike's (Mikes 914, local shop) old shop in the background. When they did the resto they installed a /6 bulkhead mount, so I take it Dave found a six to put in it? It's a good deal but I would still change the carbs. You should be able to sell them to help offset the price of a new set of 44IDF's. The DCNF's are a good carb and I think they have the float valve upgrade, but they would be better off in a street Bug, bus or a T3. My DCNF's in the squareback are real Berg and they still hiccup in fast corners. I wasn't crazy about the linkage as well, but that would be an easy fix. If it includes the exhaust it's a total score. The engine is fresh, all the tin, etc. is restored, so I'd say that 4k Canadian (about $3000USD) is a good price. QUOTE Is that a canadian flag on the coil? We canucks are proud of our old flag as well (IMG:style_emoticons/default/wink.gif) |
Ray Warren Engine Apr 2 2004, 07:16 PM
synthesisdv Looks like a good rig to me.
The GA case is no bi... Apr 2 2004, 07:23 PM
Mark Henry The DCNF's are a real good street carb, but I ... Apr 2 2004, 09:38 PM
Bleyseng Have it dyno'd then offer some money for it ba... Apr 2 2004, 09:45 PM
Mark Henry A DCNF with velocity stacks. Apr 2 2004, 09:48 PM
Tom Perso Dump the dcnf's.... They stink in the twisties... Apr 2 2004, 10:19 PM
rhodyguy how much is it?
kevin Apr 2 2004, 10:24 PM
Ray Warren $4000 CDN Apr 3 2004, 05:52 PM
Ray Warren Mark you might know this engine.
I think Mike work... Apr 3 2004, 05:57 PM
MattR Is that a canadian flag on the coil? :o Apr 4 2004, 03:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 10:44 AM |
