Do 911 SC rear hubs fit our rear bearings? |
TorqueJunkie |
Mar 15 2011, 06:41 PM
Newbie Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None |
Wondering if the SC rear hubs fit the rear 914/4 bearing/trailing arm? Trying to convert my axles to 100mm using SC stub axles, but need the matching rear hub to slide into? Anyone know?
TorqueJunkie |
Mar 16 2011, 09:10 PM
Good to know that it will fit the bearings. I already have the 85 Carrera rear calipers installed with the spacer and vented 85 disks. I also have the SC stub axle which has the proper 100mm 6 bolt pattern i want. If the hubs fit in the bearings then it is perfect. Have a friend bringing me 911 hubs to compare the SC stub axles to and see if the have same spines as well.
Lo-Fi Version | Time is now: 1st June 2024 - 08:11 AM |
