Fuel line help, I am confused |
gendent |
Mar 18 2011, 10:57 AM
Member Group: Members Posts: 89 Joined: 30-March 10 From: Lewison ID Member No.: 11,528 Region Association: Pacific Northwest |
73 2.0 L d jet 914 With the fuel pump relocated to the forward position in the tierod compartment--- I am installing new fuel lines and I have lost my orientation. As the two lines exit the firewall the larger one goes on up through the forward/rear grommet into the engine space? Then it connects to the passenger/driver side fuel rail? I believe I have thinge messed up because I turned the key on and fuel spilled out the front drain hole just behind the tierod compartment. Another learning opportunity for me.
Thanks, Jim |
tod914 |
Mar 18 2011, 11:12 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
The larger line is the feed line. When the pump is located in the rear of the car, it gets the step hose attached to it, then to the filter, then a 7mm ID line into the pump. Not sure how the plumbing is worked out when it's relocated. Think there would be a size issues.
Lo-Fi Version | Time is now: 7th June 2024 - 01:43 PM |
