mounting engine stand adapter to engine, how does this attach? |
hot_shoe914 |
Mar 20 2011, 08:59 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
SLITS |
Mar 20 2011, 09:27 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The two large holes fit over the transmission mounting studs.
The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. |
hot_shoe914 |
Mar 20 2011, 09:36 AM
The two large holes fit over the transmission mounting studs. The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. Thanks slits. Does the flat side go to the engine? |
SLITS |
Mar 20 2011, 09:42 AM
The two large holes fit over the transmission mounting studs. The four smaller holes are to mount the arms of the engine stand plate. I threaded mine for 3/8" bolts to attach the arms of the engine stand to the adapter. The notch with the hole (at bottom of your pic) is to mount the flywheel lock. Sometimes it takes some doing to arrange the arms of the engine stand to fit semi-correctly. Oh, I have two of the adapters. I would have edited the image, but I don't have photoslop on this 'puter. Thanks slits. Does the flat side go to the engine? There is a relief that fits the case machined/cast into one side of the adapter (beveled side). That goes against the case to accommodate the lip on the case, so the answer is NO! I mount the adapter to the opposite side of what you have shown. I love being contrary to JP. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:42 AM |
