Output shafts, re-installing |
Randal |
Mar 22 2011, 04:47 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Tightening and torquing the output shafts on a 901. I guess I'm a bit worried about over torquing the bolts that hold on the output shaft. After stripping one of the flange holes I'm worried that I could be doing something wrong and stripping this bolt would mean tearing the transmission down. Once bit I guess. For some reason they just keep on tightening and won't move (using the old type torque wrench with a movable lb indicator) up to 60lbs. So is there any way that something could be wrong with such a simple installation. I understand the torque setting to be 60ft lbs Thanks. |
J P Stein |
Mar 23 2011, 11:12 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Them bolts probably wouldn't give you any trouble......untill the worst possible time you can imagine. (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 12:36 AM |
