Output shafts, re-installing |
Randal |
Mar 22 2011, 04:47 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Tightening and torquing the output shafts on a 901. I guess I'm a bit worried about over torquing the bolts that hold on the output shaft. After stripping one of the flange holes I'm worried that I could be doing something wrong and stripping this bolt would mean tearing the transmission down. Once bit I guess. For some reason they just keep on tightening and won't move (using the old type torque wrench with a movable lb indicator) up to 60lbs. So is there any way that something could be wrong with such a simple installation. I understand the torque setting to be 60ft lbs Thanks. |
J P Stein |
Mar 22 2011, 05:36 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Are you speaking of the *stretch bolts* in the center of the output flanges? If so, you'd better stop twisting and find out what the torque is supposed to be. I can't recall & I've sold all my technical manuals to MikeK.
Randal |
Mar 23 2011, 10:37 AM
Are you speaking of the *stretch bolts* in the center of the output flanges? If so, you'd better stop twisting and find out what the torque is supposed to be. I can't recall & I've sold all my technical manuals to MikeK. Woo, did I get some bad information. The Hayes manual says 25-29 lb f ft Umm....maybe I should change those bolts that I stretched to 50 lb f ft? |
ChrisFoley |
Mar 23 2011, 11:01 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Umm....maybe I should change those bolts that I stretched to 50 lb f ft? (IMG:style_emoticons/default/w00t.gif) Signs point to YES |
Randal |
Mar 23 2011, 11:41 AM
Umm....maybe I should change those bolts that I stretched to 50 lb f ft? (IMG:style_emoticons/default/w00t.gif) Signs point to YES Who sells them? |
Lo-Fi Version | Time is now: 6th June 2024 - 06:56 PM |
