> Model Specific Information
> 1970 European Wiring Harness, Fog Light Switch?
proto31
post Nov 30 2009, 12:10 PM
I placed this post in the Garage as well, but maybe it's more appropriate here. So, I'm installing my wiring harness (4 cylinder), it is a european harness. I'm making this assumption based on one main observation (although there are others that seem to support it). The observation- this is a new harness (unfortunately I do not have the part number... sad.gif ), there are NO wires going to what would be the side marker lights. Nothing (absolutely certain) has been cut, I can trace all wires and there never were any side marker light wires.
So, my problem is this, there seems to be no wiring coming out of the harness in the passenger compartment area for a fog light switch, there are, however, wires for fog lights up near the front bumper area where they should be. The main wire (white with a yellow stripe) enters the passenger compartment area and goes to a relay, which then jumps directly to the combination relay, from there there are no wires that would normally go to a switch.
I know that there was some different functionality with the Euro fog light operation, but what exactly was the difference? Do the fog lights turn on any time the headlights are on, meaning no need for a fog light switch? Do I need a special head light switch?
Dan
RON S.
post Mar 21 2011, 11:19 AM
9140430841, FINALLY RUNNING
QUOTE(SirAndy @ Nov 30 2009, 01:20 PM) *
QUOTE(dr914@autoatlanta.com @ Nov 30 2009, 10:29 AM) *
but you will notice that they will work with the high beams rather than the low beams like the usa cars
Huh? (IMG:style_emoticons/default/confused24.gif)
I have to dis-agree with the Dr. ...
I have never ever seen a German car where the fog lights are wired to work with the high beams. Ever.
The fog lights only work with the low beams and will shut off automatically when you switch to the high beams.
(IMG:style_emoticons/default/bye1.gif) Andy
Dear Sir Andy,
I must say, that this thread about fog lights is certainly one records.
1st. about my car. It is a 914/6 #9140430841 delivered in Germany, and brought back over by an Army serviceman in the 80's.
Full blown Euro model. No BS here. I have owned the car for the last 12 years now. Stripped down to bare, and ground up resto.
The Euro cars had Driving lights on them in liew of fog lights. My car had these still on it when I bought it. I also noticed that there was no switch for the driving lights, nor was there a hole in the vinyl dash fascia as if there might have originally been one that some one had earlier removed. I quickly bought a fog light switch to make up for this missing switch only to find out that there was no loose pigtail plugs for the switch to plug in to. I spent many an hour going back and forth to my '74 2ltr USA 914 to compare the wiring behind the dash, and shortly found that no one had cut or mangled any of the original wiring in my Euro 6'r.
As it stands, the Euro 6's driving lights are wired right to the headlights. Mine come on when the High Beams are activated not low beams. They are off when the low beams are on. That makes for one bright viewing area at night. Also, on my car, the driving lights are wired for a flash-to-pass feature. They activate if I pull the dimmer switch toward me when the headlights are off, or on low beam.
I thought the same as this threads author, that some one monkeyed with the wiring. Now I feel more secure that the Euro cars were wired different, probably due to different lighting laws.
I also noticed that there also is no plug for the switch on the brake master cylinder either.
Ron (IMG:style_emoticons/default/biggrin.gif)
Jasfsmith
post Mar 22 2011, 07:23 AM
Interesting. My Swiss car #1113 has driving lights that will only come on with the high beam, and it does have a switch on the dash. I can flash them when in low beam as well.
Go figure.
post Mar 23 2011, 03:18 PM
Resident German
QUOTE(Jasfsmith @ Mar 22 2011, 06:23 AM) *
If you can flash the fog-lights, someone did indeed change your wiring ...
http://www.jwesteng.com/porsche/914/fog.htm
ArtechnikA
post Mar 24 2011, 06:12 PM
rich herzog
QUOTE(SirAndy @ Mar 23 2011, 05:18 PM) *
He's not talking about fog lights, he's talking about the driving lights...
( My Euro 6 had them too... )
Since they come on with the high beams (when enabled by the dash switch) of course they flash when on low beams - just like the high beams do...
And yes, they flash even when the headlights are down.
The high beams come on when the headlights are down too - just it's hard to see. But flash on, they do.
It's all the same relay, it just depends on if the 'enable' wire goes to the high-beam (driving) or low-beam (fog) circuit. It's on the wiring diagram...
post Mar 24 2011, 08:30 PM
Resident German
QUOTE(ArtechnikA @ Mar 24 2011, 05:12 PM) *
Well i'll be damned ...
German cars, especially of that period didn't have "driving lights" they way American cars have them.
The only thing i can think of is that because the headlights were otherwise hidden, Porsche added a additional driving light option to replace the fog-lights???
I can honestly say i have never seen this on any other German car of that vintage.
Time to whip out my PET copy and do some digging ...
(IMG:style_emoticons/default/type.gif)
ArtechnikA
post Mar 25 2011, 04:36 AM
rich herzog
QUOTE(SirAndy @ Mar 24 2011, 10:30 PM) *
If you are thinking about 'driving light' in the context of 'running light' - that's not it.
These are (very) high-intensity clear-lens supplemental pencil-beam headlights.
I've seen a couple pair come through the classifieds here. I wish I'd had the foresight to take the pair from my car... I might have a picture but I doubt it'll show much... IIRC they were Hella lights and took an H1 lamp.
And since they came on only with the high beams (except, of course, with the flash-to-pass activated) the headlights wouldn't be hidden when they were in use.
But there is that flash-to-pass function, which /6's mightta needed on the Autobahn, and contemporary 1,7's maybe not...
This is a nice rationalization, but I expect the practical reason is that all the stalk, relay, and headlight function was 911 bits on the /6's, and they just didn't change anything from the way the 911's worked.
I would love to see if a little-known 911 headlight mode made it into Euro /6's -- when the parking (city) lights are on (first detent on the headlight switch, illuminates a green dot in the cluster) the 'flash-to-pass' illuminates the _low beams_. I thought this was quite clever and I've never seen it documented - I stumbled onto it one night...
MDG
post Mar 25 2011, 02:07 PM
Wolf in wolf's clothing.
QUOTE(ArtechnikA @ Mar 25 2011, 06:36 AM) *
These? I bought these Euro lights off Gerold last year.
ArtechnikA
post Mar 25 2011, 02:16 PM
rich herzog
QUOTE(MDG @ Mar 25 2011, 04:07 PM) *
Maybe. I think so.
I don't remember the vertical lines, but then it's only been 25 years since I last saw mine, so I couldda forgotten a small detail.
At the time I had no idea how rare and special they were, and I always thought I'd be getting the car back 'real soon' ...
Anyway, when Gerold put those up I rember thinking they were just like mine...
proto31   1970 European Wiring Harness   Nov 30 2009, 12:10 PM
dr914@autoatlanta.com   yes certainly no side marker light wires but that ...   Nov 30 2009, 12:29 PM
proto31   yes certainly no side marker light wires but that...   Nov 30 2009, 12:43 PM
SirAndy   but you will notice that they will work with the ...   Nov 30 2009, 02:20 PM
RON S.   but you will notice that they will work with the...   Mar 21 2011, 11:19 AM
SirAndy   probably due to different lighting laws. That Sir,...   Mar 21 2011, 02:06 PM
Jasfsmith   Interesting. My Swiss car #1113 has driving lights...   Mar 22 2011, 07:23 AM
SirAndy   I can flash them when in low beam as well. If yo...   Mar 23 2011, 03:18 PM
Jasfsmith   I can flash them when in low beam as well. If y...   Mar 24 2011, 07:33 AM
ArtechnikA   I can flash them when in low beam as well. If y...   Mar 24 2011, 06:12 PM
SirAndy   He's not talking about fog lights, he's ta...   Mar 24 2011, 08:30 PM
ArtechnikA   He's not talking about fog lights, he's t...   Mar 25 2011, 04:36 AM
MDG   These are (very) high-intensity clear-lens supple...   Mar 25 2011, 02:07 PM
ArtechnikA   These? I bought these Euro lights off Gerold last...   Mar 25 2011, 02:16 PM
MDG   These? I bought these Euro lights off Gerold las...   Mar 25 2011, 03:26 PM
Cap'n Krusty   A question for Andy. If there were not 914 drivin...   Mar 24 2011, 05:56 PM
RON S.   probably due to different lighting laws. That Sir...   Mar 26 2011, 04:36 PM
RON S.   [quote name='SirAndy' post='1448734' date='Mar 24...   Mar 26 2011, 05:01 PM
ArtechnikA   Here's the pics you are asking for of...   Mar 26 2011, 05:15 PM
RON S.   Here's the pics you are asking for o...   Mar 26 2011, 06:27 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:24 PM
