> Converting to Carbs, What is a good setup for F Pump and Pressure
falconfp2001
post Mar 24 2011, 02:57 PM
Pancho Pantera
I'm gonna setup dual carbs and would like to use the stock Fuel Pump but I'm trying to figure out how to setup the Pressure Regulators.
My idea is to keep my return line to the gas tank and just have two regulators. One before the carbs and another after.
Anyone have a good suggestion?
Thanks
jmill
post Mar 25 2011, 05:21 PM
Green Hornet
QUOTE(jimkelly @ Mar 25 2011, 06:47 AM) *
would 30 gph be ok for my V8 ??
Be careful when you look at pumps. It may deliver 30 GPH but that's not at 3 psi. At 3 psi I bet it puts out only 15 GPH like the facet.
Remember that fuel = hp. The facet says it's good to about 150 hp (IMG:style_emoticons/default/bs.gif) . If your V8 is making only 150 hp why bother with the conversion at all. The Holley HP 125 flows 110 GPH at 7 psi. Its good for about 700 hp.
falconfp2001   Converting to Carbs   Mar 24 2011, 02:57 PM
jmill   If I were you I'd save a ton of cash and get a...   Mar 24 2011, 04:02 PM
dirk9141973   :idea: Ok think this out little bit ? Sell the old...   Mar 24 2011, 04:29 PM
jjackson   :agree: Ran CB pump for years on several motor com...   Mar 24 2011, 05:04 PM
jt914-6   As has been said....get a CB pump up front with a ...   Mar 24 2011, 05:15 PM
Cap'n Krusty   We have a name for people who use the stock FI pum...   Mar 24 2011, 06:10 PM
Elliot Cannon   We have a name for people who use the stock FI pu...   Mar 24 2011, 09:00 PM
moparrob   I went with the Holley 125 low pressure pump and t...   Mar 24 2011, 08:53 PM
Elliot Cannon   CB Performance rotary pump. "Works fine, las...   Mar 24 2011, 08:58 PM
jmill   http://www.914world.com/bbs2/uploads_offsite/i95...   Mar 24 2011, 09:18 PM
NJ914Guy   My shop is just wrapping up my 1973 2.0. Went wit...   Mar 24 2011, 09:28 PM
jmill   Had a Facet on a dual carbed high reving 1914 cc V...   Mar 24 2011, 09:45 PM
falconfp2001   Think I like this Regulator I also like the Holle...   Mar 25 2011, 02:10 AM
NJ914Guy   Yep, heard good and bad about the Facet and CB Rot...   Mar 25 2011, 05:33 AM
Ericv1   Yep, heard good and bad about the Facet and CB Ro...   Mar 25 2011, 04:11 PM
jimkelly   would 30 gph be ok for my V8 ??   Mar 25 2011, 05:47 AM
Root_Werks   would 30 gph be ok for my V8 ?? Jim, hopefully ...   Mar 25 2011, 07:06 AM
jimkelly   ok - i should have said - i have this friend who p...   Mar 25 2011, 01:17 PM
McMark   I prefer to go with a higher end pump and a qualit...   Mar 25 2011, 03:58 PM
nathansnathan   From my experience with rotary pumps, they say the...   Mar 25 2011, 04:12 PM
jmill   would 30 gph be ok for my V8 ?? Be careful when...   Mar 25 2011, 05:21 PM
markb   I had a facet on my carbed motor. Hated it. Noisy,...   Mar 25 2011, 09:44 PM
NJ914Guy   Had her out today again for about a 40min run. Th...   Mar 25 2011, 09:45 PM
jimkelly   sounds good - but i know i am gonna get me a good ...   Mar 26 2011, 06:33 AM
falconfp2001   what kind of distributor are you running?   Mar 26 2011, 02:11 PM
NJ914Guy   I am running the old Bosch 009 with points elimina...   Mar 26 2011, 10:17 PM
Steve73   What about this for a fuel Pump? http://www.tenn...   Aug 7 2011, 10:40 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:21 AM
