> 3.2 motronic question, my fuel pump is not coming on at key start
buck toenges
post Apr 15 2011, 02:56 PM
Everyone,
I haven't fooled around with my motronic electrical system for awhile. I am getting my 3.2 914 out of hibernation and I am not getting the fuel pump to turn on and the engine is turning over but not firing up. I replaced the dme relay which is the usual suspect but still not getting the engine to start even when I spray some starting fluid into the maf .
Does the fuel pump run through the dme relay and/or the motronic brain? I have also had a problem in the past where I had to connect a wire from the maf to the positive side of the coil to get spark and ignition of the engine.
I am going to go over the bentley book this week end but thought I would get some ideas from the 914 experts.
Thanks,
Buck
jim912928
post Apr 15 2011, 03:23 PM
...another thought...was a separate fuse box installed for the 3.2l wiring? could be up to three fuses...1 for fuel pump (to cover an inline fuse), but 2 others that feed the coil and feed the dme relay with power.
- Lo-Fi Version Time is now: 9th July 2025 - 04:09 PM
