> One messed up build thread. Nothing's gonna be right, I've been neglecting one of my cars. I'm a bad man.
rohar
post Apr 14 2011, 06:16 PM
So I've been playing with this thing a bit and collecting parts while the wife had me busy rebuilding most of the house. Now that's over and I've got most of the construction debris out of the garage so I thought I'd start a build thread to document whatever progress occurs now that I have time to get to work on this thing.
I fell out of cars for a couple of years while I chased around the country with my career. Tough to build a car while you're moving every 6 months. When we wound up back in Spokane permanently, I bought this chassis as my birthday present. 1975, originally a 1.8. Chassis is pretty clean. I've already installed billet front hubs and redrilled rears at 4x114.4 so I could keep my enkeis from a previous project, they'll probably get powder coated black before this is all over. Also went with the upgraded master cyl and 3" 911 front calipers.
(IMG:http://www.914world.com/bbs2/uploads_offsite/public.bay.livefilestore.com-9685-1302826581.1.jpg)
Only slightly scary rust is in the hell hole. Longs look pretty good and hell hole should be a pretty easy fix. The pic makes it look worse than it feels under a screwdriver. Obviously the batt tray is a bit shot:
(IMG:http://ftdaha.bay.livefilestore.com/y1pxcbo8_qRm_qDebALZgK1eNo5rQv8wqteySoAnLt4MnxxtuJ8BIc4TP6-9gfFSWid1qUhqUgX3fi7mIcfPcm73-GZjsOEn-Wi/P1010059.jpg)
The engine and tranny are out of a 2.8l 12v V6 A4. It seems to fit well after a bit of the trunk was relieved of it's dignity:
(IMG:http://www.914world.com/bbs2/uploads_offsite/oh1xza.bay.livefilestore.com-9685-1302826582.2.jpg)
The throttle comes out the back of the variable runner length manifold so it would stick into the trunk, except it's symmetrical so I should be able to turn it around and gain some space after I grind the power steering pump mounts off the block.
The output flanges on this tranny have a HUGE diameter AND they're offset by quite a few mm. I'm going to stick with stock size CV joints for now and see where that goes. 200ft/lbs shouldn't grenade them immediately. To pull this all together, I had a local guy I've worked with before throw some stainless on the lathe:
(IMG:http://ftdaha.bay.livefilestore.com/y1ppkgXonLknIqta8AInPF-NZz2tGpZigmTQ3jxQVeibDYn6wzACYV40QBs6Cn_BMO17rfXNbuVSLJ72yu_EB70PXnAsVcy8UGt/P1010058.jpg)
A bit heavy, but I intentionally left a bunch of material there in case I have to go to bigger CVs later. Risky move, but I think I'm gonna take it. Too late now in any case.
As you can see, the belt array is directly in line with where the stock cross bar was, and with the audi tranny, the crank (and whole engine) are a bit lower than the stock type IV so motor mounts aren't gonna be as easy as I had hoped:
(IMG:http://www.914world.com/bbs2/uploads_offsite/public.bay.livefilestore.com-9685-1302826582.3.jpg)
The steel for the mounts is in the garage. Tomorrow, I start tackling that problem.
rohar
post Apr 17 2011, 11:43 AM
Ok, I'm two days behind where I wanted to be. Started cutting steel for the motor mounts, pics to follow shortly. I keep forgetting how much time it takes to cut steel if you have any attention to detail...
rohar   One messed up build thread. Nothing's gonna be right   Apr 14 2011, 06:16 PM
silver74insocal   :popcorn: :yikes: :yikes: :worship: cant wait ...   Apr 14 2011, 06:27 PM
rohar   :popcorn: :yikes: :yikes: :worship: cant wait...   Apr 14 2011, 07:04 PM
kg6dxn   If you swap to 930 CV's you can adjust the eng...   Apr 14 2011, 06:28 PM
rohar   If you swap to 930 CV's you can adjust the en...   Apr 14 2011, 06:36 PM
okieflyr   I've got probably 1200 miles including auto-xi...   Apr 14 2011, 07:18 PM
rohar   I've got probably 1200 miles including auto-x...   Apr 14 2011, 07:54 PM
okieflyr   I've got probably 1200 miles including auto-...   Apr 14 2011, 08:18 PM
rohar   [quote name='rohar' post='1459960' date='Apr 14 2...   Apr 14 2011, 08:26 PM
rick 918-S   Cool, I like the Audi engines. Just becareful shop...   Apr 14 2011, 07:22 PM
rohar   Cool, I like the Audi engines. Just becareful sho...   Apr 14 2011, 07:58 PM
rohar   Cool, I like the Audi engines. Just becareful sho...   Sep 4 2011, 05:00 PM
raw1298   This is the start of a great build. Looking forwar...   Apr 14 2011, 08:08 PM
okieflyr   Yep, type 4 inners and outers. If your going bigg...   Apr 14 2011, 08:43 PM
rohar   Yep, type 4 inners and outers. If your going big...   Apr 14 2011, 08:53 PM
rohar   Ok, I'm two days behind where I wanted to be. ...   Apr 17 2011, 11:43 AM
okieflyr   Bump.. Are you sparking anything up yet? :welder:   Apr 17 2011, 08:29 PM
rohar   Bump.. Are you sparking anything up yet? :welder...   Apr 17 2011, 10:50 PM
rohar   Some pics and progress from sunday. Had to roll t...   Apr 18 2011, 09:28 AM
rohar   Slow going... Yesterday I managed to get the cros...   Apr 24 2011, 10:19 AM
rohar   WOOT! Front motor mountage, and I think I lef...   May 1 2011, 12:23 PM
rohar   Managed to knock out one tranny mount today. I...   May 29 2011, 09:41 PM
rohar   WHOOHOO! The engine, tranny and chassis are n...   May 30 2011, 05:11 PM
RJMII   I've been contemplating getting rid of my mind...   May 30 2011, 05:26 PM
jcambo7   I've been contemplating getting rid of my min...   May 30 2011, 05:32 PM
rohar   This is the hard part. I'll loose virtually n...   May 30 2011, 05:30 PM
rohar   Ok, I slept on it. Better judgment got the best o...   May 31 2011, 09:16 AM
rohar   Looks like the engine/tranny portion of this proje...   Jun 11 2011, 09:02 AM
JRust   Looking great! Keep up the progress. This is t...   Jun 11 2011, 09:37 AM
rohar   Thanks JRust. I'm still pushing. At this poi...   Jun 11 2011, 09:47 AM
JmuRiz   Cool build, are you keeping the 12v stock or hot-r...   Jun 11 2011, 06:40 PM
rohar   It's gonna remain "fairly" stockish....   Jun 11 2011, 08:34 PM
brp986s   What's preventing the gearbox from swinging la...   Jun 11 2011, 09:20 PM
rohar   What's preventing the gearbox from swinging l...   Jun 11 2011, 09:43 PM
rohar   As promised, but a bit late. Butt shot: http://w...   Jun 16 2011, 11:43 AM
rohar   Ok, got some time on my hands again. Work's b...   Jul 29 2011, 11:22 AM
Andyrew   The S6 radiator has an integrated oil cooler? I ...   Jul 29 2011, 12:03 PM
rohar   This one does, and the label on the box says S6 so...   Jul 29 2011, 12:48 PM
rohar   Ok, so I managed to get the frames/mounts done tod...   Jul 29 2011, 08:52 PM
rohar   I managed to get the rails and clamps for the radi...   Jul 30 2011, 10:40 AM
rohar   Alright, all the mounting is done for the radiator...   Jul 30 2011, 10:01 PM
okieflyr   Now things are moving! What are you thinking ...   Jul 31 2011, 04:40 PM
rohar   Now things are moving! What are you thinking...   Jul 31 2011, 09:15 PM
rohar   alright, I promised pics this morning, I failed. ...   Jul 31 2011, 10:15 PM
kg6dxn   Fab never goes as fast as you want it to. I must h...   Jul 31 2011, 10:19 PM
rohar   Fab never goes as fast as you want it to. I must ...   Jul 31 2011, 10:44 PM
rohar   Well, that trip didn't go completely as planne...   Aug 2 2011, 09:54 PM
rohar   So I spent all day working with the hall sensors o...   Aug 3 2011, 05:52 PM
rohar   Ok, kg6dxn more picks. There's one of these o...   Aug 13 2011, 09:05 PM
rohar   Air goes there, and yes, it's winking at you: ...   Aug 14 2011, 05:11 PM
rohar   Ok, got a little side tracked by some shindig in t...   Aug 22 2011, 08:41 PM
majkos   :popcorn: :beer3: You're doing JUST fine...   Aug 22 2011, 09:38 PM
rohar   Alright, time to take a timeout from pushing on th...   Aug 24 2011, 11:31 AM
rohar   So the wife banned me from working on the car unti...   Sep 4 2011, 03:54 PM
kg6dxn   I think you should keep the Audi bolt pattern too....   Sep 4 2011, 04:03 PM
rohar   I mentally kicked that around for about 8 seconds....   Sep 4 2011, 04:50 PM
okieflyr   It sounds as though youv'e got some good local...   Sep 4 2011, 08:25 PM
rohar   It sounds as though youv'e got some good loca...   Sep 4 2011, 08:38 PM
rohar   Damn, that was more passion than logic. Obvously,...   Sep 4 2011, 08:55 PM
NORD   Been following this build. Keep going and when you...   Sep 5 2011, 09:08 AM
rohar   Been following this build. Keep going and when yo...   Sep 5 2011, 10:31 AM
Chris Scott   Rohar, Thanks for the funny comments on my thread....   Sep 6 2011, 09:25 PM
rohar   3 30' trailers filled with stuff in the last 4...   Sep 23 2011, 04:16 PM
rohar   Finally in the new home. The shop is bigger than ...   Oct 7 2011, 04:28 PM
rohar   So I finally made it back to Seattle to pick up ha...   Oct 20 2011, 12:52 PM
rohar   So I've managed to get enough of the shop sort...   Nov 2 2011, 02:28 PM
okieflyr   So I've managed to get enough of the shop sor...   Dec 15 2011, 07:59 PM
rohar   Ok, so I tabled the tubing for now but I have made...   Nov 11 2011, 08:28 PM
aircooledtechguy   You ARE a glutton for punishment aren't you?? ...   Nov 12 2011, 12:33 PM
rohar   Glutton for punishment? Yeah, pretty much. So ...   Nov 12 2011, 01:24 PM
NORD   Did I hear that the Porsche Parade will be in Salt...   Nov 12 2011, 02:02 PM
rohar   WOOT! I'll plan on being an "officia...   Nov 12 2011, 02:11 PM
rohar   So with the acquisition of the 944, I've come ...   Dec 15 2011, 05:46 PM
rohar   I'm back to the iron block v6 so steel tubes a...   Dec 15 2011, 08:24 PM
rohar   I've got the day off and the shop is warm, but...   Dec 23 2011, 04:52 PM
aharder   Get Up :bump: Get up :bump: get up :poke: No...   Dec 23 2011, 05:05 PM
rohar   Damned thing is out. Got lazy and found a new way...   Dec 23 2011, 06:54 PM
rohar   Hey, you pull a v6 from a 914 your way, I'll p...   Dec 23 2011, 07:09 PM
aircooledtechguy   Hey, you pull a v6 from a 914 your way, I'll ...   Dec 24 2011, 10:01 AM
rohar   Red-neck two post lift. . . All you need now is...   Dec 24 2011, 10:36 AM
Jeff Hail   Hey, you pull a v6 from a 914 your way, I'll ...   Dec 26 2011, 12:12 AM
rohar   That tranny sure looked smaller on the other engin...   Dec 24 2011, 05:31 PM
messix   he's lifting the engine into place from the fl...   Dec 26 2011, 12:18 AM
JRust   he's lifting the engine into place from the f...   Dec 26 2011, 12:45 AM
rohar   As many times as I've mounted and unmounted an...   Dec 26 2011, 08:55 AM
rohar   Alright, things aren't going as fast as I...   Dec 26 2011, 03:11 PM
rohar   Alright, the motor mounts on the /8 are a bit much...   Dec 29 2011, 05:49 PM
rohar   Lookie here, one finished passenger side motor mou...   Dec 30 2011, 01:56 PM
rohar   Same song, second verse. A little bit faster and ...   Dec 31 2011, 07:40 PM
rohar   It ain't mounted yet, but I'm well on my w...   Jan 1 2012, 07:36 PM
rohar   Turns out the passenger side of the yoke hit the s...   Jan 2 2012, 10:54 PM
Chris Scott   Sounds like a good time to change the rear suspens...   Jan 4 2012, 02:42 AM
nsr-jamie   You mentioned you have 3inch 911 calipers on the f...   Jan 4 2012, 10:47 AM
rohar   Sounds like a good time to change the rear suspen...   Jan 4 2012, 12:13 PM
rohar   Lookie what happened over lunch: http://i910.phot...   Jan 4 2012, 01:35 PM
rohar   The beginnings of a new, more sleek tranny mount. ...   Jan 5 2012, 09:12 PM
rohar   I mounted a tranny: http://farm6.staticflickr.com...   Jan 6 2012, 04:15 PM
Socalandy   looks like Jeremy from Top Gear :confused: . didnt...   Jan 7 2012, 10:43 AM
rohar   Andy, please tell me you know who that is! It...   Jan 7 2012, 11:59 AM
Andyrew   ^ I agree! I was going to make a joke about t...   Jan 7 2012, 12:48 PM
- Lo-Fi Version Time is now: 16th November 2026 - 05:19 PM
