Smog Test, Can't pass cruise CO |
jaminM3 |
Apr 20 2011, 12:02 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I have searched the forum and I can't find any info on getting your car to pass the smog test?
I have a '74 with a 2.0. It passed in fall of '09 and I drove it to RRC. The only thing I have done since then is relocate the gas pump to the front. This has successfully stopped the vapor locking issue. Does somebody out there now what I need to do to adjust the FI? It passes the idle test fine but the cruising test fails for Carbon Monoxide. You can smell it too. I think it is running pretty rich. (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Apr 20 2011, 12:15 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Also, do the simple stuff first.
Tuneup, new points, plugs, cap and rotor. Set valve adjustment Set dwell Set timing. In that order... Rich |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:08 AM |
