Smog Test, Can't pass cruise CO |
jaminM3 |
Apr 20 2011, 12:02 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I have searched the forum and I can't find any info on getting your car to pass the smog test?
I have a '74 with a 2.0. It passed in fall of '09 and I drove it to RRC. The only thing I have done since then is relocate the gas pump to the front. This has successfully stopped the vapor locking issue. Does somebody out there now what I need to do to adjust the FI? It passes the idle test fine but the cruising test fails for Carbon Monoxide. You can smell it too. I think it is running pretty rich. (IMG:style_emoticons/default/confused24.gif) |
jaminM3 |
Apr 20 2011, 04:04 PM
It says the CO% standard is 5%, mine tested 7.36% and 10.4% last fall when I tried it the first time. I brought it to a local mechanic to install the 911 front suspension and brakes and had him look at the tune. That is why it went down.
It passed the year before and I only drove it like a thousand miles. You can smell it, there is something wrong with the tune. |
ArtechnikA |
Apr 21 2011, 10:24 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
It says the CO% standard is 5%, mine tested 7.36% and 10.4% last fall Are you running premium gas? Stop. run the lowest octane that will prevent detonation, at least for the duration of the test. Higher octane == more resistance to burning. unburned fuel == high CO. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:46 PM |
