New Member- Chris Julian- 1974- 918 6.4, Blood Sweat and Fears |
Chris Julian |
Apr 8 2004, 03:33 PM
Member Group: Members Posts: 159 Joined: 19-March 04 From: SF Bay area Member No.: 1,821 |
Hey Guys,
I'm new to the board and forums in general so please forgive the technical stumblings I am about to put you through. I've attached a couple of photos of my project. Brad R says the BBS is messed up so I can't really preview the pics, I hope it works, Ha Ha he says. the car is a 1974- 914 that died early in it's prime from an engine fire. The car bounced around for many years as a v8 conversion project when I found it in 1991. As with most of this projects it started out as a 1-2 year minor project and grew into something much more. The car is more street rod then authentic Porsche, although I have always respected German engineering, and the Porsche name, I wanted to create my own car. Here's a couple of highlights, Body: The body kit is an "American International Racing (AIR)" fiberglass kit which I had to cut way down. The original rear fenders had the overall width of the car at 84"-86"s wide. After I cut 4"s off each side the thing still looks like a Testerosa from behind. The car is painted Maytag White and looks more like a race car and less like a modern day Porsche. Engine: The motor is a 4 bolt 350 with a 400 crank i.e. stroker motor 383 cubes, Trick Flow heads, loopy cam, and a recent purchase, soon to be installed, 4 48 IDA Webers with a Moon Racing manifold. I will get the car on the road first, then install/tune the Webers (which seems to be the number one reason these carbs ever get sold, they are very hard to tune but once perfected, the throttle response of a nitro car. They must be tuned by a professional with a dyno and lots of spare jets?. Cooling, I am running two 1" copper lines down the center tunnel inside the car with 16AN bulkhead fittings at both firewalls and braided 1 1/8" OD hose connecting the motor and radiator (I am worried about the ID of this hose), large aluminum racing radiator with two powerful "Scotts" electric fans, I have extensively cut into the front inner fenders but have reinforced all the suspension tie-in points with sturdy roll cage downbars/xbars, the car probably has 75'+ of 1 1/2" steel tubing. The water pump is Rod Simpsons cast AL housing with the Chrysler impeller. The front air inlet/opening is about 160 sq. inches, the exit somewhere near double the inlet. If that doesn't do it, I'll install dual oil coolers and Renegades Radiator. Tranny: Pantera ZF, any knowledge of the ZF tranny/installation would be very helpful (shifter, linkage, gearing, ect...) The car has dated Centerline Champ 500 wheels, Tires are 345's out back and 285's up front on 15" rims. Need bigger tires/rims and brakes. I can't find a tire wider then a 335 in a larger rim size (17"-20"). Any suggestions?. Chris Julian Attached thumbnail(s) |
ablose58 |
Apr 8 2004, 04:12 PM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
(IMG:style_emoticons/default/aktion035.gif) Way cool project! (IMG:style_emoticons/default/aktion035.gif) That thing looks like it will fly like a rocket sled on rails, and welcome aboard. (IMG:style_emoticons/default/mueba.gif) PS you gotta take me for a ride when done I love a good adrenaline rush. AL (IMG:style_emoticons/default/MDB2.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 06:14 AM |
