Headlight switch swapping, Can I swap early and late switches? |
scoobykvn |
Apr 22 2011, 06:38 AM
Member Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
I have a late 'wide body' switch in my car that is wired with a harness from a '76 that seems to have an internal short. The gauge lights always have some power going to them that fluctuates as I move the headlight switch. I also have switch from an earlier year that I want to try to use. Is it possible to swap these switches? If so, how is this done, since there is 1 more wire on the late style switch.
914Mike |
Apr 22 2011, 09:54 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I have a late 'wide body' switch in my car that is wired with a harness from a '76 that seems to have an internal short. The gauge lights always have some power going to them that fluctuates as I move the headlight switch. I also have switch from an earlier year that I want to try to use. Is it possible to swap these switches? If so, how is this done, since there is 1 more wire on the late style switch. IIRC, all you have to do is find a dual connector for the extra wire, and figure out which wire it jumpers onto... I thought all 914 switches were the same, 914-613-414-10, and narrow ones are VW parts? >Edit Apparently there is a newer number for '72 up, 914-613-414-15. END Edit< |
Lo-Fi Version | Time is now: 9th June 2024 - 01:45 PM |
