| Dr Evil |
Apr 24 2011, 07:50 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I initially was doing this to show to my clinic participants, but I figure that everyone can benefit from this information. I was doing this on Kansas914's gear box and just happened to find that his input shaft bearing was no more (see pics).
Step one can be done in two ways. I choose to use a tapered punch and place it in a bolt hole with the tip pressing against a rib. The 19mm bolt in the flange should not be torqued very much so this is not an issue. If the drift starts to bend significantly, switch to method #2. Method #2 is to put two bolts in the flange and use a bar of some sort, down low on the flange surface, against the bolts. ![]() Once the 19mm bolt is removed you just pull the flange out. Remove all the cover bolts and tap the cover at the arrowed locations to remove it. ![]() |
| montoya 73 2.0 |
Apr 24 2011, 08:03 PM
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
That looks familiar. I believe mine was broken in half and had to be replaced at the clinic. Luckily it stayed in place.
Dr Evil Quick transmission inspection Apr 24 2011, 07:50 PM
Dr Evil Once the cover is removed you can now inspect the ... Apr 24 2011, 07:55 PM
Dr Evil Here is where the bearing parts should be. Apr 24 2011, 07:56 PM
scotty b glad you made it home :beer2: Apr 24 2011, 08:05 PM
Kansas 914 Holy Crap! The car sat for 15 years - then I c... Apr 25 2011, 06:51 AM
hot_shoe914
Did you have doub... Apr 25 2011, 07:57 AM
zymurgist
Did you have dou... Apr 25 2011, 08:22 AM
jimkelly so that bearing is optional -sweet : ) Apr 25 2011, 07:51 AM
Dr Evil Mike, I'll talk with you for options. I have r... Apr 25 2011, 07:59 AM
Kansas 914
Mike, I'll talk with you for options. I have ... Apr 25 2011, 08:03 AM
warrenoliver I am on 24hr OB call today, though...
[/quote]
... Apr 25 2011, 09:39 AM
KELTY360
:ttiwwp... Apr 25 2011, 09:43 AM
Root_Werks :bump:
PNW Tranny Clinic is only a couple days a... May 5 2011, 10:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd December 2025 - 01:22 AM |
