| ewdysar |
Apr 25 2011, 12:48 AM
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Hi guys,
I'm finally getting around to installing my 915 with Wevo sideshift into my Renegade conversion. I'd like to go with a hydraulic clutch setup. Anybody have a comprehensive list of parts? Will the 993 pedal cluster fit in the 914? Anybody use an annular throwout setup, like Wevo has for their racing clutches? Unfortunately, I believe that the Wevo piece doesn't have enough throw for the conversion clutch/pressure plate. Thanks for your help... Eric |
| PRS914-6 |
Apr 25 2011, 05:59 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
| ewdysar |
Apr 26 2011, 10:02 AM
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric |
| rohar |
Apr 26 2011, 10:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric I'm pretty sure the Neo914 used a 993 cluster. Since the master is virtually the same for the 993 and the Audi unit, I've been looking at both solutions pretty close. I'm thinking I'll probably end up with a variant of what PRS914-6 did. |
| ewdysar |
Apr 26 2011, 12:54 PM
Thanks for the responses so far. From what I've seen, I'm leaning towards what PRS914-6 did for his setup. I'm still wondering if anyone has put a 993 cluster in a 914 yet.... Eric I'm pretty sure the Neo914 used a 993 cluster. Since the master is virtually the same for the 993 and the Audi unit, I've been looking at both solutions pretty close. I'm thinking I'll probably end up with a variant of what PRS914-6 did. So after reading lots of the Neo914 threads, I believe that answer is that the 993 cluster will not work in the 914 (at least Neo didn't make it work). The 964 cylinder can be grafted into the cluster, but it lives inside the cabin. I'm still headed towards the PRS914-6 solution... |
ewdysar Hydraulic clutch options - V8 and 915 Apr 25 2011, 12:48 AM
Loser_Cruiser Prs, I totally missed that on your build. Awesome. Apr 25 2011, 12:10 PM
RON S. Eric,
I have converted/grafted the 964 sl... Apr 25 2011, 06:06 PM
Andyrew I think im going to install a master cylinder from... Apr 26 2011, 10:31 AM
PRS914-6 A few things to keep in mind......
1. There is n... Apr 26 2011, 11:57 AM
rohar It's been too long since I read those threads.... Apr 26 2011, 02:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:13 PM |
