Thought my clutch cable broke |
StratPlayer |
Apr 28 2011, 09:07 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
The other day I was driving the 914 when suddenly I lost my clutch. Damn my clutch cable must have broken.
Yesterday I got to the pedal assembly and discover the clutch pedal wasn't turning the shaft that its attached to. The roll pin that holds the pedal to the shaft had broken and wasn't allowing the pedal to rotate the shaft. Better than having to replace the cable. Now to find the correct size roll pin to replace the broken one. (IMG:style_emoticons/default/smile.gif) |
StratPlayer |
Apr 29 2011, 10:57 AM
I got the problem fixed yesterday. I had to drill out the hole for the pin to enlarge it a bit. Then I used a solid hardened pin instead of a roll pin. Pin fit in the hole just right, tapped it in place a wa la everything works just fine.
Lo-Fi Version | Time is now: 11th June 2024 - 07:37 AM |
