Fresh Air Box & Blower Motor, Can It Be Removed / Repaired Without Removing the Fuel Tank? |
ptravnic |
May 1 2011, 09:05 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
My gas tank is about 5/8 of the way full and I'd like to get the car into paint by the end of the week but want to get the fresh air motor working first.
Can it be removed & reinstalled without removing the gas tank? |
type47 |
May 2 2011, 03:51 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I recently installed an air box into the project car and I don't see how it could be removed or installed with the gas tank in. If all you're doing is re and re the motor, you might look to see about just unbolting the motor part of the housing; it's held on by 2 - 6mm hex head bolts. Unfortunately, all the cables complicate the matter so it's probably easier just to remove the whole assembly. It was a MAJOR PIA to install that box.
Lo-Fi Version | Time is now: 11th June 2024 - 10:09 PM |
