914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Dudes:
I live in southeastern WI and I need to get an emission test before I can get collectors plates on my '76 914. Once I get the plates, I will not be required to get tested anymore. Do you guys have any tricks or recommendations on how I might help it pass? I've replaced the plugs, air filter, fuel filter, injectors, resealed the tank (fresh gas) and installed a used cat, but I'm missing the air pump. I think my '76 came with an airpump installed from the factory, but a PO must have removed it (and the cat). I've also installed a good used (ansa?) muffler into which I've installed the used cat. Once (if) I pass, I'll remove the cat and put the bypass pipe back in. Any good tips? (besides lising it as residing in another county where testing is not required)? Thanks for any ideas that might help. Andy... |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
If they check for the physical presence of the air pump, you're hosed anyway. Before the test, drive the living crap outa the car and get it HOT. Leave it running when you get to the testing station. Pick a time when it will be the slowest so you get your car in right away before it cools down. If it's running well and tuned properly, it will pass.
Lo-Fi Version | Time is now: 1st July 2025 - 10:47 AM |
