> 72 Engine "knocks"
mikeatrpi
post Apr 11 2004, 08:50 AM
I found a 72 914 1.7L that the owner is casually selling (he's not listing it in papers; it's parked in the back of a parking lot with a sign in the window). The owner describes the engine as "needing work" and making a "knocking sound." I haven't heard it run myself, but apparently it starts. What could this be, and how much to fix it?
The paint is silver but not shinny, body is straight with a little rust by the driver's rear bumper, and the top leaks. I haven't gone through Pelican's checklist for rust yet. Based on what I've told you, does $2k US sound fair? I'm looking for my first real project car.
Thank you for any advice you can provide!
-Mike
TheCabinetmaker
post Apr 11 2004, 09:04 AM
I drive my car everyday
Engine knocks could be alot of things. Most likely, a rod bearing, or dropped valve seat. A dropped seat can cause the valve to hit the top of the piston making one hell of a racket. That can also cause a rod bearing to flatten and allow the rod to slap the crank. It will at the very least need the heads redone, or a complete top end rebuild. 1.7 heads are much tougher than the 2.0 heads so my guess is rod bearings
mikeatrpi   72 Engine "knocks"   Apr 11 2004, 08:50 AM
Bleyseng   "Knocks" like in a rod knock? I wouldn't pay ...   Apr 11 2004, 08:59 AM
ArtechnikA   everybody is so concerned about the engines... eng...   Apr 11 2004, 09:04 AM
vsg914   Engine knocks could be alot of things. Most likely...   Apr 11 2004, 09:04 AM
!   It's worth what YOU think it is....if it's...   Apr 11 2004, 09:05 AM
nebreitling   are you sure the sound isn't just a maladjuste...   Apr 11 2004, 10:58 AM
mikeatrpi   Thanks for the tips so far. I went out earlier an...   Apr 11 2004, 11:34 AM
mikeatrpi   As promised, an update. First, the car is a 73, n...   Apr 11 2004, 06:02 PM
ArtechnikA   what's it like at the bulkhead, behind the sea...   Apr 11 2004, 07:05 PM
SirAndy   it looks OK on the outside, but you should have ta...   Apr 11 2004, 07:21 PM
TimT   Where in NY is this car? Most of NY is "the rust ...   Apr 11 2004, 07:28 PM
mikeatrpi   An update- I got a chance to drive the 914 today....   May 10 2004, 08:55 PM
- Lo-Fi Version Time is now: 6th July 2025 - 03:56 PM
