| 914gem |
Apr 3 2004, 09:51 PM
Member ![]() ![]() Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 |
All you V8 guys and guys that have built these pocket rockets which kit or combination of parts work best. Such as quality of parts, service, instructions, cost,ect. How about some testimonys and storys from V8 people about their cars, what they used and what they wouldn't use if they had it to do over again.
| turbo914v8 |
Apr 11 2004, 07:14 PM
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 |
Brad,
As I understand it, RH is instructing people to drill three 1/8 holes in the thermostat to prevent the hoses from popping off when the thermostat is closed. I have not done it yet so cannot comment on its effectiveness. I am however considering it. Regards, Turbo Paul. |
914gem V8 Conversion Kits Apr 3 2004, 09:51 PM
chunger Get the Renegade radiator setup. It's worth t... Apr 3 2004, 11:52 PM
John2kx
FriarJohn In addition to asking Brad specifically and this B... Apr 5 2004, 10:51 PM
Brad Roberts Watcha thinking about 914GEM ?? I know you have ac... Apr 5 2004, 11:37 PM
neo914-6 I tried to build a Jaide (who) kit in the 80's... Apr 6 2004, 01:23 AM
914gem Hi Brad, not up to to much. I have a KEP adapter a... Apr 6 2004, 07:20 AM
Brad Roberts Renegade all the way. No questions.
Hopefully you... Apr 6 2004, 09:53 AM
boxstr 914GEM here is a 327 with a 283 crank brings it do... Apr 6 2004, 10:30 AM
turbo914v8 Hi all
I used the old Renegade kit from the 90... Apr 6 2004, 12:17 PM
914gem Hi Boxstr, your engine compartment looks nice, whe... Apr 6 2004, 12:22 PM
JmuRiz That 305 looks pretty cool. I've always loved... Apr 6 2004, 12:24 PM
chunger Turbo914v8,
Do you have pics?
-'Chung Apr 6 2004, 03:28 PM
Brad Roberts Talk to us Turbo.. show us some pics.. I knew you ... Apr 6 2004, 04:48 PM
neo914-6 Yeah Paul G, pics of your beast would be NICE. Ch... Apr 6 2004, 06:28 PM
boxstr 914GEM thanks the pics are taken before I got the ... Apr 6 2004, 07:32 PM
turbo914v8 I have been in contact with both Chris and Harry r... Apr 7 2004, 09:31 AM
soloracer Welcome Turbo914V8! That is a ton of power to... Apr 7 2004, 11:43 AM
turbo914v8 soloracer,
I took many hours and seam welded the ... Apr 7 2004, 01:10 PM
Brad Roberts Hey Paul,
Nothing larger than a 930 CV will fit i... Apr 7 2004, 02:06 PM
turbo914v8 Brad,
Thanks for the information. I guess the obv... Apr 7 2004, 06:26 PM
chunger Hello,
Is there a difference between 930 CV's... Apr 7 2004, 11:24 PM
Brad Roberts Chung,
Call them and find out what the "kit" incl... Apr 8 2004, 12:28 AM
Brad Roberts Paul,
I dont actually have a conversion car. Ever... Apr 8 2004, 12:31 AM
chunger Do the 911 CV's hold together ok with the 2 pi... Apr 8 2004, 12:39 AM
Brad Roberts The holes for the pins are too big to be tapped. T... Apr 8 2004, 12:46 AM
chunger Uh oh,
Which part of the flanges do not fit right... Apr 8 2004, 01:00 AM
andys Brad,
Are the 930 CV's the same size as the l... Apr 8 2004, 09:53 AM
turbo914v8 Brad,
Your work must be really grand if you are s... Apr 8 2004, 10:26 AM
Chris914n6 Hi Chung, glad you made it here.
I found a relati... Apr 10 2004, 01:04 AM
jridder >Billet water pump housing anyone
Cool. Of cours... Apr 11 2004, 12:00 AM
neo914-6 Seems to me if you have a clean sheet, engineering... Apr 11 2004, 02:00 AM
John2kx For comparison, this is the Renegade pump. I pref... Apr 11 2004, 04:45 AM
John2kx hikgf Apr 11 2004, 04:48 AM
John2kx The fixed inlet fitting on Dessert pump will more ... Apr 11 2004, 05:01 AM
BIGKAT_83 Davids(Desert Hybrids) steel pump housing lines up... Apr 11 2004, 06:45 AM
John2kx Bob,
The inlet fittings do appear to work when pu... Apr 11 2004, 07:28 AM
John2kx Looking at the RH pump again and comparing to Dese... Apr 11 2004, 08:09 AM
John2kx Renegade now offers this piece to aid in eliminati... Apr 11 2004, 08:21 AM
BIGKAT_83 I used a molded rubber hose with a 90 bend it it f... Apr 11 2004, 08:54 AM
turbo914v8 Some really great ideas in regards to fixing the p... Apr 11 2004, 10:20 AM
Brad Roberts I have access to the small bead roll device needed... Apr 11 2004, 10:49 AM
Mike T
boxstr John Thomas had posted athread about the thermosta... Apr 11 2004, 07:20 PM
John2kx ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:55 PM |
