tom9146 |
Member ![]() ![]() Group: Members Posts: 54 Joined: 22-December 05 From: Ottawa Canada Member No.: 5,307 ![]() |
2.2 liter ,side shifter , new clutch , release bearing and pressure plate .Alberta Car
can be daily driver , looking for a new project. Not perfect or the price would be 20k ,paint is original color Irish green new shift bushings hell hole is solid , battery tray has never had to be replaced more pics avail for serious buyer . Located in Ottawa Canada , Licensed and insured as a six cyl. FOR SALE 1972 Porsche 914/6 , Green yellow , brown interior , $17500.00 5 speed ,78000 miles ( Conversion ) 2.2 liter six cylinder ‘S cams ‘ Weber carbs ,K&N Air intake Stainless steel brake lines Cross drilled and vented brakes 5 bolt Wheels ,Fuchs Alloys 6 x 16” Sway Bars front and rear Side shift transmission and shift mechanism 19 mm 911 Master cylinder M calipers front 3 inch spacing Widened calipers rear with handbrake functional . Vented 911, cross drilled rotors front and rear New Brake pads front and rear New Bilstein front inserts ( shocks ) New Ball joints New rear shocks Boge and springs #140 lbs New Speedo Cable and Angle Drive New Carpets , Front Euro turn signal lenses New Seat Belts ( and retractors ) New Fuel Pump ( relocated to front trunk ) Center Console with Gauges , clock , voltage . gas gauge 911 oil pressure /oil temp gauge Porsche Oil tank Porsche heat exchangers and exhaust Electric Windshield washer pump New tires 205/55 /60 x 16 Pirelli P6 Call Tom D’Amico 613-837-8553 or e-mail tdamico@aei.ca ![]() ![]() |
tom9146 |
More pics [attachmentid=259
920] ![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2025 - 12:19 PM |
