FS-Front 911 struts complete $400., Half shafts, interior, deck & engine lids, tons of small parts, etc. |
Mike D. |
May 17 2011, 09:35 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
This is all still available. Buyer was a no show with on instalation day. Maybe he got hit by a bus...
REAR 5 LUG IS SOLD Complete 5 lug conversion set up. All four corners. 911 Boge front struts (will fit Konis) ATE slotted vented rotors, M calipers with Pads, and Earls SS brake lines. Could use some new inserts. Rear trailing arms, with good bushings and wheel bearings. stub axles and Drilled hubs. 914-6 solid rear discs and stock 914-4 rear brake calipers. Also set of steel lug nuts. Needs rear springs and struts Rotors thickness - fronts 20.5mm, rears 11mm (min. 19mm/9.5mm) $800. plus very expensive shipping or you can pick up. I am also available to do the installation and alignment. Provided you have the wheels or buy the ones below. Wheels are 15x6 Fuch Repros. They are polished and have good center caps. Need new tires, let me know and I will have the rubber removed if you want. SOLD 140# springs, SOLD Engine Lids $50.each One red, one Yellow BRAND NEW - NOS Type 4 vavle covers $100/pair SOLD passenger door handle/pull $20 Half shafts with CVs - good used, will need to be cleaned and packed $80.00 Steel rocker panels, need some help - SOLD Front and rear deck lids - rear has some rust from someone putting on a spoiler, front is in good shape, both Yellow. Front $60. Rear $35. 911 chain housings and covers 930.105.101,102,105 &106 - $50 for the set. head light motors $20.each targa tops, 1 early, 1 late missing bolister, - later one has chipped corners on pass side. $30. ea. I also have tons of other 914 parts, Looking for something, shoot me a PM. all prices do not include shipping. Service, installation, and troubleshooting also available. Attached thumbnail(s) |
Jeffs9146 |
May 17 2011, 04:26 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I will take the springs!
And I may still be interested in the rear of 5-lug set up but getting them to the Bay Area might be tough unless someone who is comming to the Transmission Clinic at my house in June and might be able to bring them up!!? |
Lo-Fi Version | Time is now: 7th June 2024 - 03:50 AM |
