Progress, The 2011 Hershey show gave me another shot of motivation |
saigon71 |
May 2 2011, 07:33 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I have now attended the Hershey Porsche show three times without an operational teener...NOT being part of the caravan is getting old. (IMG:style_emoticons/default/mad.gif)
Finally got my new inner long welded in with doubler plates on all seams. Verified the incline of the new long with an incline gauge (with the car level) following Jeff Hails build thread. Door operates well! Entire inner long has been coated with rust encapsulator. Still have a long way to go but I am hoping that this was the toughest part. Thanks to Scotty B, Jeff Hail, and everyone else who has posted a build thread on this topic. I have read all of them & learned a lot. (IMG:style_emoticons/default/beerchug.gif) Bob |
saigon71 |
May 15 2011, 06:42 PM
Cutting - continued:
Luckily, it looks like the rust only crept about an inch or so up into the firewall...this shot is looking between inner & outer firewall. The damaged area: Short on money, but long on time & sheet metal, I decided to try to fabricate a replacement piece...started by cutting the bottom curved piece at the base of the firewall and went from there. The most difficult part for me was the compound bend, where I had to cut slits to get the right contour, then fill with weld. I left it a little long in all dimensions, so I could trim it as needed for the final fit. Still need to weld all seams on this, but I am pleased with how it is shaping up: |
draganc |
May 21 2011, 03:46 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Cutting - continued: Luckily, it looks like the rust only crept about an inch or so up into the firewall...this shot is looking between inner & outer firewall. The damaged area: Short on money, but long on time & sheet metal, I decided to try to fabricate a replacement piece...started by cutting the bottom curved piece at the base of the firewall and went from there. The most difficult part for me was the compound bend, where I had to cut slits to get the right contour, then fill with weld. I left it a little long in all dimensions, so I could trim it as needed for the final fit. Still need to weld all seams on this, but I am pleased with how it is shaping up: Great work man! |
saigon71 |
May 23 2011, 08:26 PM
Cutting - continued: Luckily, it looks like the rust only crept about an inch or so up into the firewall...this shot is looking between inner & outer firewall. The damaged area: Short on money, but long on time & sheet metal, I decided to try to fabricate a replacement piece...started by cutting the bottom curved piece at the base of the firewall and went from there. The most difficult part for me was the compound bend, where I had to cut slits to get the right contour, then fill with weld. I left it a little long in all dimensions, so I could trim it as needed for the final fit. Still need to weld all seams on this, but I am pleased with how it is shaping up: Great work man! Thanks...a lot of time was invested in that piece...hope it fits well! |
Lo-Fi Version | Time is now: 4th June 2024 - 04:46 PM |
