> Can somebody ID this new idle quirk?, starts & runs well -- until warm
Prospectfarms
post May 31 2011, 10:43 PM
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
O.K., I'm better now... D-jet is driving me to drink.
The 1.7 starts and runs well until it warms up. After 10 min. idling smoothly @ 900 it hesitates two or three times and stops idling at all, which means I can't keep it running long enough to set the timing. I can keep it going by feathering the throttle, but my nice smooth idle is gone. I reproduced the symptom three times in a row today.
By clamping off the Vac hoses one-by-one it appears the FI components seem to be doing what they're supposed to. No other vacuum or capacitance probs. found so far. Haven't checked the injectors.
This started after I repaired the ground strap on my distributor -- must have bumped something else. CHT?
I have the FI diagnostic checklists and am working on them. If this was a carburetor I'd say it was running with a clogged idle jet (IMG:style_emoticons/default/wacko.gif) . These symptoms seem specific and uncommon. At least I've not seen others posts that describe the same thing. Did I miss one?
Prospectfarms   Can somebody ID this new idle quirk?   May 31 2011, 10:43 PM
kg6dxn   Try this... L Jet Manual   May 31 2011, 10:52 PM
Prospectfarms   Try this... L Jet Manual Thnkz Mike, Although...   Jun 1 2011, 06:16 AM
SirAndy   CHT? Could be. I have seen this exact behavior wh...   May 31 2011, 10:54 PM
Prospectfarms   CHT? Could be. I have seen this exact behavior w...   Jun 1 2011, 06:46 AM
vsg914   The cold start valve does not come on till the air...   Jun 1 2011, 07:17 AM
Prospectfarms   The cold start valve does not come on till the ai...   Jun 1 2011, 07:46 AM
Bartlett 914   The cold start valve does not come on till the ai...   Jun 1 2011, 07:47 AM
Prospectfarms   The cold start valve does not come on till the a...   Jun 1 2011, 07:50 AM
underthetire   Yep, i'll bet AAR myself. Should idle about 15...   Jun 1 2011, 08:33 AM
vsg914   Unplug the hose to the AAR at the air cleaner and ...   Jun 1 2011, 08:38 AM
Tom   From above; Great info! thanks. Assumed inc...   Jun 1 2011, 01:53 PM
Prospectfarms   From above; The ECU adjusts fuel mixture b...   Jun 1 2011, 10:43 PM
Bartlett 914   I think the idle screw is at the end of its t...   Jun 2 2011, 07:56 AM
charliew   Tom, is it really Magala Red?   Jun 1 2011, 04:28 PM
ThinAir   Even though this problem started after a specific ...   Jun 1 2011, 10:56 PM
Prospectfarms   Generally with D-Jet systems you want to start wi...   Jun 2 2011, 04:48 AM
Tom   The information I have is Paul Anders' stuff a...   Jun 2 2011, 10:42 AM
Prospectfarms   The information I have is Paul Anders' stuff ...   Jun 2 2011, 11:15 AM
r_towle   Unplug and cap all vacuum lines at the plenum. the...   Jun 2 2011, 11:13 AM
Prospectfarms   Unplug and cap all vacuum lines at the plenum. th...   Jun 2 2011, 11:28 AM
r_towle   Unplug and cap all vacuum lines at the plenum. t...   Jun 2 2011, 11:44 AM
r_towle   look in the classics forum here for Cap'n crus...   Jun 2 2011, 11:17 AM
Prospectfarms   look in the classics forum here for Cap'n cru...   Jun 7 2011, 08:36 PM
Prospectfarms   PS: Ill go through those procedures, set valve cle...   Jun 2 2011, 11:34 AM
benalishhero   Open loop in modern EFI systems refers to the engi...   Jun 2 2011, 05:55 PM
Prospectfarms   Thanks benalishhero, So the word "open" ...   Jun 2 2011, 06:42 PM
Prospectfarms   Unplug and cap all vacuum lines at the plenum. th...   Jun 4 2011, 09:46 PM
Prospectfarms   Follow up and diagnosis. Ultimately it was the fue...   Jun 15 2011, 10:08 PM
ThinAir   Besides, starting with the basics, the other thing...   Jun 4 2011, 11:04 PM
Prospectfarms   It's sounding a bit to me like a solder point...   Jun 5 2011, 06:13 AM
Prospectfarms   Update: Pulled ECU and tested resistance of CHT ...   Jun 5 2011, 12:00 PM
Prospectfarms   Update: Here's what I am presently dealing ...   Jun 5 2011, 10:03 PM
Prospectfarms   ThinAir, did you do more work on your son's 91...   Jun 7 2011, 08:06 AM
Tom   You should measure the value of the CHT when it is...   Jun 6 2011, 07:18 AM
Prospectfarms   You should measure the value of the CHT when it i...   Jun 6 2011, 08:03 AM
Prospectfarms   You should measure the value of the CHT when it ...   Jun 6 2011, 09:59 AM
Tom   I have heard of cracked plenums causing a vacuum l...   Jun 6 2011, 12:08 PM
Prospectfarms   I have heard of cracked plenums causing a vacuum ...   Jun 6 2011, 12:55 PM
ThinAir   This actually all started with this: http://www.91...   Jun 7 2011, 03:36 PM
Prospectfarms   This actually all started with this: http://www.9...   Jun 7 2011, 08:22 PM
speed metal army   give us the part # of that pump! :)   Jun 15 2011, 10:23 PM
Prospectfarms   give us the part # of that pump! :) Began ...   Jun 15 2011, 10:36 PM
ThinAir   Congratulations on figuring it out! Persistenc...   Jun 16 2011, 12:47 AM
- Lo-Fi Version Time is now: 15th July 2025 - 03:00 AM
