Squeeking in PR wheel, Doesnt go away durring braking |
Andyrew |
Jun 3 2011, 01:16 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
So I have a little bit of squeeking in the pass rear wheel while driving, sounds like pads, but it doesnt go away or change (much) while braking. Semi racing pads. New bearings (1k miles or so). I dont feel a drag (while rolling to a stop), but its a a bit harder to roll than my CRX so I think there may be some dragging. Calipers were rebuilt 6 years ago and have been sitting most of the time. No proportioning valve. Fresh fluid in ~ 4 years ago (sitting since). Parking cables are disconnected.
What should I look for when I have it on the lift? I am going to adjust the rear brake clearance and test function of the rears. (They were adjusted when fluid went in 4 years ago, but Who knows if its still in spec). Thanks all! Andrew |
dion9146 |
Jun 3 2011, 02:28 PM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
I have the same thing going on with my Drivers side rear wheel. Everything is tight and within spec, but I think it is brake pad related because I can 'turn it on and off' by applying the brakes. Either that, or the disk is floating and the center nut really isn't tight anymore.....
Lo-Fi Version | Time is now: 15th June 2024 - 12:59 PM |
