Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
O.K., I'm better now... D-jet is driving me to drink. The 1.7 starts and runs well until it warms up. After 10 min. idling smoothly @ 900 it hesitates two or three times and stops idling at all, which means I can't keep it running long enough to set the timing. I can keep it going by feathering the throttle, but my nice smooth idle is gone. I reproduced the symptom three times in a row today. By clamping off the Vac hoses one-by-one it appears the FI components seem to be doing what they're supposed to. No other vacuum or capacitance probs. found so far. Haven't checked the injectors. This started after I repaired the ground strap on my distributor -- must have bumped something else. CHT? I have the FI diagnostic checklists and am working on them. If this was a carburetor I'd say it was running with a clogged idle jet (IMG:style_emoticons/default/wacko.gif) . These symptoms seem specific and uncommon. At least I've not seen others posts that describe the same thing. Did I miss one? |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
You should measure the value of the CHT when it is warm.
Tom |
Lo-Fi Version | Time is now: 15th July 2025 - 02:41 AM |
