Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
O.K., I'm better now... D-jet is driving me to drink. The 1.7 starts and runs well until it warms up. After 10 min. idling smoothly @ 900 it hesitates two or three times and stops idling at all, which means I can't keep it running long enough to set the timing. I can keep it going by feathering the throttle, but my nice smooth idle is gone. I reproduced the symptom three times in a row today. By clamping off the Vac hoses one-by-one it appears the FI components seem to be doing what they're supposed to. No other vacuum or capacitance probs. found so far. Haven't checked the injectors. This started after I repaired the ground strap on my distributor -- must have bumped something else. CHT? I have the FI diagnostic checklists and am working on them. If this was a carburetor I'd say it was running with a clogged idle jet (IMG:style_emoticons/default/wacko.gif) . These symptoms seem specific and uncommon. At least I've not seen others posts that describe the same thing. Did I miss one? |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
You should measure the value of the CHT when it is warm.
Tom |
Prospectfarms |
You should measure the value of the CHT when it is warm. Tom Thanks, Tom my last "idea" (IMG:style_emoticons/default/screwy.gif) -- to ground the CHT when the engine was about to stall-- was a round-a-bout way of checking it warm. Your note brought me back to reality . Unconsciously, I think I was trying to avoid the trouble of removing the ECU when it was hot. (IMG:style_emoticons/default/rolleyes.gif) (I've so far done my resistance checks at the ECU 24 pin harness) I'll check the warm CHT at the ECU pin and also check the warm MAP values at the same time. (IMG:style_emoticons/default/idea.gif) I'm going to do this now and report back later. Appreciate the help! |
Lo-Fi Version | Time is now: 15th July 2025 - 02:39 AM |
