> What's Compression Ratio got to do with it?
ThinAir
post Jun 6 2011, 11:23 PM
Best friends
When I built my 2.0L I had the understanding that if you wanted to run Regular fuel the highest compression ratio you could have was 8:1. I don't have any idea now where that came from.
In the thread about his air-cooled event, Jake just posted this: "The 356 engine is a 2.4, it made 224HP @ 9:1 CR on pump gas."
Now I know that there is more to one of Jake's engines than just the CR, but it got me to wondering:
1. What is the maximum CR you can run with Regular fuel?
2. What is the relationship of CR to performance? Do you always get more HP by running higher CR if everything else is the same?
Understanding this concept might be helpful the next time someone builds an engine, buys one from Jake, or has one built for them by someone else.
Tom_T
post Jun 6 2011, 11:47 PM
TMI....
CR is the key to HP (& TQ too), cuz it's thicker air! (IMG:style_emoticons/default/biggrin.gif) ... pun on thinair!
... that's why modern cars with turbos are all running premium fuel (excl. turbo diesel of course).
I have a good article on it somewhere that gives the CR vs. Octane reqts. that I'll try to find, but you can get a good idea by looking at new car specs for which CRs require premium vs. those for regular or mid-grade..
IIRC 8.0:1 was about the max you could run the 1970's unleaded regular on - & remember that unleaded initially ONLY came in regular, until they fully switched over to unleaded only at all grades in the 80's. The problem could come with knocking/pinging in those areas where regular can be as low as 85 (vs. 87), then maybe bump to their mid-grade 88-89 in those areas if it pings, or premium 90-91 if it still pings.
Pinging/knocking is extra bad for our aircooled/oilcooled Type IV engines, cuz it makes them run hotter.
BTW - the 2.0's & 1.7s/1.8s were made 7.6:1 for CA smog regs of the day, which now you can tweak in other ways & still keep within smog limits & higher CR (although 75 & earlier are smog exempt in CA). Porsche/VW only wanted one 2.0 for all 50 states, so all USA bound GAs had the 7.6:1 CR heads, vs. the 8.0 "Euro" heads for the rest of the world GB motors, but probably 60% of the 2.0s went to the US market.
ThinAir   What's Compression Ratio got to do with it?   Jun 6 2011, 11:23 PM
ThinAir   It just occurred to me that perhaps the highest CR...   Jun 6 2011, 11:32 PM
messix   too many variables to give a short answer. combus...   Jun 6 2011, 11:38 PM
Tom_T   CR is the key to HP (& TQ too), cuz it's t...   Jun 6 2011, 11:47 PM
Bleyseng   CR is the key to HP (& TQ too), cuz it's ...   Jun 7 2011, 09:51 AM
Vacca Rabite   Pump gas means only that it came from a commercial...   Jun 7 2011, 07:45 AM
detoxcowboy   The bolts in the cases can only take so much..   Jun 7 2011, 10:15 AM
Prospectfarms   When I built my 2.0L I had the understanding that...   Jun 8 2011, 12:49 PM
Dave_Darling   By default, when people talk about compression rat...   Jun 8 2011, 01:35 PM
Jake Raby   Everything.   Jun 8 2011, 05:57 PM
Madswede   [EDIT: I just realized that I'm once again doi...   Jun 9 2011, 02:04 PM
ThinAir   ... but then again, since you're carb'd ...   Jun 9 2011, 03:15 PM
Madswede   ... but then again, since you're carb'd...   Jun 10 2011, 11:16 AM
Prospectfarms   I don't think its permitted to cite links to o...   Jun 9 2011, 10:17 PM
Dave_Darling   I don't think its permitted to cite links to ...   Jun 10 2011, 07:20 PM
Prospectfarms   I don't think its permitted to cite links to...   Jun 10 2011, 09:17 PM
Maltese Falcon   ..and then add in some un-natural aspiration (boos...   Jun 9 2011, 10:52 PM
Don M   Compression ratio is directly related to environme...   Jun 11 2011, 08:34 AM
ThinAir   I'm not planning on an engine build anytime so...   Jun 12 2011, 06:42 PM
- Lo-Fi Version Time is now: 17th July 2025 - 07:53 PM
