Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
O.K., I'm better now... D-jet is driving me to drink. The 1.7 starts and runs well until it warms up. After 10 min. idling smoothly @ 900 it hesitates two or three times and stops idling at all, which means I can't keep it running long enough to set the timing. I can keep it going by feathering the throttle, but my nice smooth idle is gone. I reproduced the symptom three times in a row today. By clamping off the Vac hoses one-by-one it appears the FI components seem to be doing what they're supposed to. No other vacuum or capacitance probs. found so far. Haven't checked the injectors. This started after I repaired the ground strap on my distributor -- must have bumped something else. CHT? I have the FI diagnostic checklists and am working on them. If this was a carburetor I'd say it was running with a clogged idle jet (IMG:style_emoticons/default/wacko.gif) . These symptoms seem specific and uncommon. At least I've not seen others posts that describe the same thing. Did I miss one? |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
Besides, starting with the basics, the other thing you'll often hear is that you should check everything else first before you look at the brain because "they never go bad". Well... almost never.
Your symptom of smelling fuel when it dies sounds alot like what happened with my son's 1.7L at RRC 2 years ago. We went around a corner, the engine suddenly died and it was obvious that it was flooded. After we got it home we went through the entire system methodically like you are doing. Because we had known good parts that we could swap we changed out AAR, MPS, etc. Finally, there was only one part left - the brain. Sure enough, after changing out that the problem went away and has never returned. If you can lay your hands on a brain that is compatible with the rest of your system, it may be worth swapping it to see if it makes a difference. It's sounding a bit to me like a solder point or circuit board that is breaking a circuit once it heats up. |
Prospectfarms |
ThinAir, did you do more work on your son's 914 since this post?
http://www.914world.com/bbs2/index.php?s=&...t&p=1129848 It indicates that a problem with the MAPS electrical connection caused the car to suddenly flood-out. Did you later determine an ECU fault? Per: Besides, starting with the basics, the other thing you'll often hear is that you should check everything else first before you look at the brain because "they never go bad". Well... almost never. Your symptom of smelling fuel when it dies sounds alot like what happened with my son's 1.7L at RRC 2 years ago. We went around a corner, the engine suddenly died and it was obvious that it was flooded. After we got it home we went through the entire system methodically like you are doing. Because we had known good parts that we could swap we changed out AAR, MPS, etc. Finally, there was only one part left - the brain. Sure enough, after changing out that the problem went away and has never returned. If you can lay your hands on a brain that is compatible with the rest of your system, it may be worth swapping it to see if it makes a difference. It's sounding a bit to me like a solder point or circuit board that is breaking a circuit once it heats up. Thanks a lot! |
Lo-Fi Version | Time is now: 15th July 2025 - 04:06 AM |
