Suspension Advice Needed, Front bars, shocks and rear springs. |
jmill |
May 22 2011, 09:08 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Building a Street/Track car, think more track than street. The car is flared with 16x7's and 16x8's. Building a 2.4 6 with 2.2S p/c's and 911 front suspension. I need some advice on front torsion bar size, rear springs, inserts/shocks, and sway bar size. Thanks. (IMG:style_emoticons/default/beer.gif)
And what do you guys think about these? Attached image(s) |
jmill |
Jun 7 2011, 09:27 PM
911 M rear calipers are a good match for the A fronts. Tarett makes a good anti roll bar. I *think* Chuck Morland (Elephant Racing) sells bronze rear bushings for the 914. Edit: Ayup, he does. $315 for the kit thru Pelican. They are my second choice. Clint from Rebel said they had a kit in the works. It's similar to their fronts with the exception of a tube insert you weld (or lock with a nut) into the trailing arm. It seems like a better fix IMHO than relying on the poly to deform. I would think they might not be true to each other and bind a bit. If they don't come through I'll go with the Elephant. You may want to go with a little more rear spring than 225. I settled with 250 to 275 depending on venue. And I had 19mm front torsions. The car pushed too much with anything less and that was without a LSD initially. No rear bar. I'm a bit worried about that myself. Chris recommended 200 and so did Clint. I went a bit heavier with you guys suggesting 250 to 275. If I push I'll install my rear bar. If I get wheel spin I'll go to a heavier spring. You'll have to excuse my ignorance. Whats the difference between the M and SC rear caliper? I don't know jack about 911 rears. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:55 PM |
