QUOTE(J P Stein @ Jun 8 2011, 08:55 PM)
I'm no expert ( no real racin' here) but have an opinion.
I think you've nailed it with the word "heat".
It is not for nothing that vented rotors are the choice for racers. Heat is a killer.
It is not just the venting but also the size of the "heat sink". If you don't want to go vented rears you should start looking for some ducting to cool the rears......tho I doubt they would work very well with solid rotors. You could also use more heat resistant pad in back....an iffy proposition till everything gets up to temp.
Personally, I'd go to vented rotors, eat the weight penalty, & be done with it.
Actually I'm not having any problems with it, No need to change to the heavy vented rear rotors
- I have all of the rear brake I can use in balance with my front S calipers
- my pad life is still about 10 full track days, so pad life is not a concern for me
- I never over heat the rear brakes.... (or fronts for that matter)
the only reason I brought it up was that Ive heard multiple people claim they don't have enough rear brake even with the proportioning valve fully open...
yet I have plenty... I can open the valve further and lock the rears first at will
so I'm just curious what is different in the set ups to make mine well balanced?
no need to change anything on mine... I've got what I want and what others can't seam to achieve.
I used to have vented rear rotors on a different teener race car
maybe if I had another 100hp I'd feel differently (although I doubt it)
but I don't need them... can't see adding the weight back if it only makes you heavier-slower....
besides. These are momentum cars. If you are heating your brakes too much with 200hp, you are just braking too much. I've known faster guys than I in teeners that have even smaller brakes without problem... they just don't brake much and they are faster for it.
actually the fastest real racers I know don't use vented. On the race tracks (don't know autox) if you talk to some of the true 914 drivers (such as Allen Johnson in a 205hp 4-cylinder) They will run laptimes faster than the 500hp mustangs, corvette's and camaro's and do it all without big brakes. You can't run those kind of lap times if your braking much.
brant
