Suspension Advice Needed, Front bars, shocks and rear springs. |
jmill |
May 22 2011, 09:08 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Building a Street/Track car, think more track than street. The car is flared with 16x7's and 16x8's. Building a 2.4 6 with 2.2S p/c's and 911 front suspension. I need some advice on front torsion bar size, rear springs, inserts/shocks, and sway bar size. Thanks. (IMG:style_emoticons/default/beer.gif)
And what do you guys think about these? Attached image(s) |
jmill |
Jun 7 2011, 09:27 PM
911 M rear calipers are a good match for the A fronts. Tarett makes a good anti roll bar. I *think* Chuck Morland (Elephant Racing) sells bronze rear bushings for the 914. Edit: Ayup, he does. $315 for the kit thru Pelican. They are my second choice. Clint from Rebel said they had a kit in the works. It's similar to their fronts with the exception of a tube insert you weld (or lock with a nut) into the trailing arm. It seems like a better fix IMHO than relying on the poly to deform. I would think they might not be true to each other and bind a bit. If they don't come through I'll go with the Elephant. You may want to go with a little more rear spring than 225. I settled with 250 to 275 depending on venue. And I had 19mm front torsions. The car pushed too much with anything less and that was without a LSD initially. No rear bar. I'm a bit worried about that myself. Chris recommended 200 and so did Clint. I went a bit heavier with you guys suggesting 250 to 275. If I push I'll install my rear bar. If I get wheel spin I'll go to a heavier spring. You'll have to excuse my ignorance. Whats the difference between the M and SC rear caliper? I don't know jack about 911 rears. |
PeeGreen 914 |
Jun 8 2011, 10:14 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I'm a bit worried about that myself. Chris recommended 200 and so did Clint. I went a bit heavier with you guys suggesting 250 to 275. If I push I'll install my rear bar. If I get wheel spin I'll go to a heavier spring. You'll have to excuse my ignorance. Whats the difference between the M and SC rear caliper? I don't know jack about 911 rears. I'd bet Chris and Clint are more on the ball than any of these guys here. Greg has said 200-225 is perfect for a 914 with no rear bar. Since Greg is an actual race engineer for a big race team and has won nationals with a 914 that gives him a lot of leverage. Chris and Clint as well have shown they know their stuff. JP, Randall, Me, Grant, are all guys with different opinions and life experiense but nothing really to show for it. Take what we say with a grain of salt (IMG:style_emoticons/default/wink.gif) If you can find a rear caliper that has a bigger piston without going to a vented rotor you will be better off. Eric will know what you can do. |
J P Stein |
Jun 8 2011, 10:37 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Greg has said 200-225 is perfect for a 914 with no rear bar. Since Greg is an actual race engineer for a big race team and has won nationals with a 914 that gives him a lot of leverage. It depends on which front T/AR bars one is using. Blanket statements (which seems odd for Greg) like that are usless.....but if you want to go with that, be my guest. Brit recently went to 325 lb rear springs which cured the push that popped up after the approx. 100 lb Subie weight gain..... in lieu of softening the front AR bar. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:07 AM |
