Suspension Advice Needed, Front bars, shocks and rear springs. |
jmill |
May 22 2011, 09:08 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Building a Street/Track car, think more track than street. The car is flared with 16x7's and 16x8's. Building a 2.4 6 with 2.2S p/c's and 911 front suspension. I need some advice on front torsion bar size, rear springs, inserts/shocks, and sway bar size. Thanks. (IMG:style_emoticons/default/beer.gif)
And what do you guys think about these? Attached image(s) |
brant |
Jun 8 2011, 08:26 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
JP,
not arguing but now I'm curious I get a ton of rear brake wear/heat never enough to want to go back to my old cars vented rear rotors... never a problem. but I'm wearing through rear brake pads 2 to 1 over the front same compound front and rear fronts are vented with S calipers (knock backs gutted) rears are 914 front early calipers moved to the back (same pad as a M caliper) I think the 914/4 front may have a tiny bit smaller piston than a true 911 front M caliper (even though the pad size is the same) maybe its the 1-2mm smaller piston? I've fabricated all new rear brake lines, but I think they were of stock diameter. I'm running an adjustable proportioning valve (that I dare not open all of the way) our engine weights were similar, although your car weight may have been a bit less than mine. still I would say similiar chassis.... yet I'm buring through 2 sets of rear pads to ever front and getting tons of rear brake. maybe heat?... maybe pad compound that is working in the heat I'm getting? I dunno... but I have AMPLE rear brakes and have to dial them off a bit I change my brake proportioning bias about once a weekend to accomodate warm, cold, or wet track now I'm curious |
Lo-Fi Version | Time is now: 11th June 2024 - 08:54 AM |
