Suspension Advice Needed, Front bars, shocks and rear springs. |
jmill |
May 22 2011, 09:08 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Building a Street/Track car, think more track than street. The car is flared with 16x7's and 16x8's. Building a 2.4 6 with 2.2S p/c's and 911 front suspension. I need some advice on front torsion bar size, rear springs, inserts/shocks, and sway bar size. Thanks. (IMG:style_emoticons/default/beer.gif)
And what do you guys think about these? Attached image(s) |
brant |
Jun 8 2011, 08:26 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
JP,
not arguing but now I'm curious I get a ton of rear brake wear/heat never enough to want to go back to my old cars vented rear rotors... never a problem. but I'm wearing through rear brake pads 2 to 1 over the front same compound front and rear fronts are vented with S calipers (knock backs gutted) rears are 914 front early calipers moved to the back (same pad as a M caliper) I think the 914/4 front may have a tiny bit smaller piston than a true 911 front M caliper (even though the pad size is the same) maybe its the 1-2mm smaller piston? I've fabricated all new rear brake lines, but I think they were of stock diameter. I'm running an adjustable proportioning valve (that I dare not open all of the way) our engine weights were similar, although your car weight may have been a bit less than mine. still I would say similiar chassis.... yet I'm buring through 2 sets of rear pads to ever front and getting tons of rear brake. maybe heat?... maybe pad compound that is working in the heat I'm getting? I dunno... but I have AMPLE rear brakes and have to dial them off a bit I change my brake proportioning bias about once a weekend to accomodate warm, cold, or wet track now I'm curious |
J P Stein |
Jun 8 2011, 08:55 PM
JP, not arguing but now I'm curious I get a ton of rear brake wear/heat never enough to want to go back to my old cars vented rear rotors... never a problem. but I'm wearing through rear brake pads 2 to 1 over the front same compound front and rear fronts are vented with S calipers (knock backs gutted) rears are 914 front early calipers moved to the back (same pad as a M caliper) I think the 914/4 front may have a tiny bit smaller piston than a true 911 front M caliper (even though the pad size is the same) maybe its the 1-2mm smaller piston? I've fabricated all new rear brake lines, but I think they were of stock diameter. I'm running an adjustable proportioning valve (that I dare not open all of the way) our engine weights were similar, although your car weight may have been a bit less than mine. still I would say similiar chassis.... yet I'm buring through 2 sets of rear pads to ever front and getting tons of rear brake. maybe heat?... maybe pad compound that is working in the heat I'm getting? I dunno... but I have AMPLE rear brakes and have to dial them off a bit I change my brake proportioning bias about once a weekend to accomodate warm, cold, or wet track now I'm curious I'm no expert ( no real racin' here) but have an opinion. (IMG:style_emoticons/default/biggrin.gif) I think you've nailed it with the word "heat". It is not for nothing that vented rotors are the choice for racers. Heat is a killer. It is not just the venting but also the size of the "heat sink". If you don't want to go vented rears you should start looking for some ducting to cool the rears......tho I doubt they would work very well with solid rotors. You could also use more heat resistant pad in back....an iffy proposition till everything gets up to temp. Personally, I'd go to vented rotors, eat the weight penalty, & be done with it. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:42 AM |
