Flywheel Crankshaft oil seal |
iamchappy |
Jun 11 2011, 12:55 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I had to replace the seal as i sprung a huge leak last week, when i pulled the flywheel off i discovered The old seal was cocked and and was not installed properly by the builder it has always leaked a little ever since i have run it, but last week it let go after only 30 miles breaking in my new clutch (IMG:style_emoticons/default/hissyfit.gif) . Lucky the clutch doesn't appear to of been contaminated by oil.
I installed a new seal in it a few days ago, but realized after that i didn't oil the inside of the seal that runs on the crankshaft (IMG:style_emoticons/default/headbang.gif) (i was rushing to get the frozen seal in place before it warmed up as it was 103ยบ that day outside) , rather than risk the chance of the rubber seal burning i decided to pull the seal out and do it over. I removed the seal this morning, the inside of the seal was full of oil up to the small holes in the case and oil weeps down from behind the center of the crankshaft. The engine is tilted back a little so i could easily remove the transmission, should the oil level be that high in the case and should oil be able to weep from behind the crankshaft. Should oil have accumulated behind the seal even though the engine has not been turned over. I am ready to install the new seal but would like to hear what you think, do you think i may have to much oil in my tank.....It registered up to the full mark on my stick when i was done adding to it when it was fully warmed up...Maybe my oil stick mark has been wrong all these years (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
sixnotfour |
Jun 11 2011, 02:17 PM
914 Wizard Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
That seal can be problematic for some , you may want to find a thread from rob930 or 930rob on pelican. He ended up making the spring a bit tighter, by making it smaller , it kinda of screws together. To solve his many rear seal wows.
Lo-Fi Version | Time is now: 14th June 2024 - 02:35 AM |
