Source? Throw out bearing?, Can't beleive thay cost $150 |
Mike Bellis |
Jun 14 2011, 10:02 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Both PP and AA and even ebay have new TB's for around $150 shipped. Is there a cheaper solution for a CSOB 914 owner? (IMG:style_emoticons/default/WTF.gif)
Rotary'14 |
Jun 14 2011, 10:20 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Both PP and AA and even ebay have new TB's for around $150 shipped. Is there a cheaper solution for a CSOB 914 owner? (IMG:style_emoticons/default/WTF.gif) The TO bearing I got with my kennedy kit was a special machined piece that you would press a regular bug TO bearing onto (but you had to cut the "ears" off of the TO bearing). It might be cheaper than using a 914 one. You should give them a call. http://kennedyenginc.com/default.aspx -Robert |
Mike Bellis |
Jun 14 2011, 10:33 PM
Both PP and AA and even ebay have new TB's for around $150 shipped. Is there a cheaper solution for a CSOB 914 owner? (IMG:style_emoticons/default/WTF.gif) The TO bearing I got with my kennedy kit was a special machined piece that you would press a regular bug TO bearing onto (but you had to cut the "ears" off of the TO bearing). It might be cheaper than using a 914 one. You should give them a call. http://kennedyenginc.com/default.aspx -Robert I'm kind of amazed there isn't a simple VW part number to replace it. I might have to buy one from McMark. He has the best deals around! |
JWest |
Jun 15 2011, 09:29 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
QUOTE I'm kind of amazed there isn't a simple VW part number to replace it. I might have to buy one from McMark. He has the best deals around! In my experience the VW throwout bearings are short-lived, while the Porsche bearing is just about bulletproof. I think you would be money behind in the long run to try to adapt a VW part in this case. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:21 PM |
