Alternative to Pertronix? |
914ltd |
Jun 15 2011, 10:33 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
I have installed at least 20 Pertronix ignitions on mostly stock 914's in my shop. The benefits are limited to dwell and related timing that does not change and eliminating points maintenance. The failure rate has been low but more than I would like, mainly because of 2 that have failed on 1 customers 914 (there have been others). Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I don't think stock 914's need MSD and other complicated and expensive ignitions. Do any of you other shop owners or experienced repairers have a trusted points replacement? Thanks! Brad Mayeur
Zundfolge |
Jun 15 2011, 02:37 PM
Senior Member Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains |
Drums66 |
Jun 15 2011, 03:21 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I thought the newer Pertronix units had solved this problem (dunno because mine is an old one that was installed a decade ago and still works fine)? ......I also thought and read that this had been aleviated? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)(shouldn't be an issue!) |
swl |
Jun 15 2011, 07:16 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Pertronix says this is a consumer fault by leaving the ignition turned on without the engine running. I thought the newer Pertronix units had solved this problem (dunno because mine is an old one that was installed a decade ago and still works fine)? ......I also thought and read that this had been aleviated? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)(shouldn't be an issue!) Last I looked the pertronix II wasn't available for our distributor. |
Zundfolge |
Jun 15 2011, 09:11 PM
Last I looked the pertronix II wasn't available for our distributor. Look again (IMG:style_emoticons/default/biggrin.gif) |
Derek Seymour |
Jun 15 2011, 09:44 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
http://www.hot-spark.com/Hot-Spark-SVDA034-3BOS4U1.htm
This is the best solution if you have a newer "brain". However it seems that during the "SMOG Wars" for lack of a better term, Bosch used the type IV as a test bed for FI technology. To sum it up stock is the best solution for any stock motor. IMHO (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 12:38 PM |
