| Prospectfarms |
Jun 15 2011, 10:33 PM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
This thing is so cheap its probably is supposed to sit inside a gas tank, but I can't see how. It's rated for almost 90 liters an hour at 45 PSI. No amperage rating but its about the same size as the OEM. Threaded +/- terminals. Intake nipple = 12 mm, pressure side = 7mm.
Helped me determine that my original three nipple Bosch pump was bad. I routed the cars fuel pump return line into the tank return line and hooked her up. Works fine right now, had to turn down the pressure regulator and it pumps up fast. No check valve that I know of but it holds more residual pressure than my old pump. Here's a link, something wouldn't permit me to attach my web archived image, sorry. https://www.napaonline.com/Catalog/CatalogI...076604&An=0 Fuel Pump - (Electric In-Line Type) - Actual MFG OEM Part Number: BSH N69133 Product Line: Bosch Fuel Pump Fitting Size[s] : Electric Fuel Pump Fuel Pump Gallons Per Hour : 22.45 Fuel Pump Pressure Rating : 45 PSI Features and Benefits: This Pump is the Original Equipment Fuel Pump. This Pump Will Provide You and Your Customer Confidence that it Will Perform Exactly Like the Original Equipment Fuel Pump because That is What it is. Warranty: Limited 12 Months |
| SLITS |
Jun 16 2011, 09:58 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Well, I just bought one to compare to the others that I have .... I may not need it, but for that price I'll keep one around.
Prospectfarms Anyone worked with this Fuel Pump? Jun 15 2011, 10:33 PM
SLITS That fuel pump is a standard configuration much li... Jun 16 2011, 07:19 AM
Prospectfarms Thanks for that info, it reduced post-install anxi... Jun 16 2011, 09:33 AM
Prospectfarms I'd like to know your opinion after you take a... Jun 16 2011, 12:17 PM
SLITS
I'd like to know your opinion after you take ... Jun 16 2011, 04:25 PM
vsg914 I just bought one at my local napa for 27.00 I hav... Jun 16 2011, 02:18 PM
scott_in_nh
I just bought one at my local napa for 27.00 I ha... Aug 7 2011, 08:41 AM
SirAndy something wouldn't permit me to attach my web ... Jun 16 2011, 02:21 PM
Prospectfarms Much obliged, Sir Andy. I'll figure out these ... Jun 16 2011, 03:28 PM
76-914
Well, I just bought one to compare to the others ... Jun 16 2011, 04:31 PM
SLITS
Well, I just bought one to compare to the others... Jun 16 2011, 05:23 PM
scott_in_nh Is anybody familiar with D&M?
http://www.dmau... Aug 7 2011, 08:46 AM
SLITS
http://www.dma... Aug 7 2011, 09:16 AM
scott_in_nh It is a problem with this vendors description, it ... Aug 7 2011, 10:01 AM
moparrob Not to hijack your thread but I do have an extra ... Aug 7 2011, 03:39 PM
ThinAir I'm running a pump that looks like the Napa/DM... Aug 7 2011, 03:44 PM
John Jentz $87 today. Aug 7 2011, 03:57 PM
Bartlett 914
$87 today.
Woo HOO :Qarl:
I suspected the... Aug 8 2011, 08:19 AM
skaufmann I bought that pump from D&M. At the time my 72... Aug 7 2011, 10:16 PM
SLITS The "in tank" pumps are totally differen... Aug 8 2011, 07:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:16 PM |
