anyone pic of stove pipe cooling?, looking into cooling for chumpcar |
usa4cheer |
Jun 17 2011, 09:14 PM
Newbie Group: Members Posts: 29 Joined: 16-February 06 From: richmond, va Member No.: 5,592 |
Looking into different cooling options for chumpcar type race. I have looked at the cali conversion, different fan configurations. fan deletes etc. and was considering a stove pipe type cooling that I have only heard of and know nothing else about.
anybody know about this thanks tim |
ChrisFoley |
Jun 17 2011, 11:34 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
This is what I did in my FProd car:
Inlet in the fog light opening of the bumper. The 6" od aluminum flex hose comes from McMaster Carr. Its a bit more expensive than galvanized straight ducting but makes a smooth route and was fairly easy to install as one continuous piece. The duct is mounted high on the firewall because I don''t use the stock engine cooling system. |
Randal |
Jun 18 2011, 09:40 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
This is what I did in my FProd car: Inlet in the fog light opening of the bumper. The 6" od aluminum flex hose comes from McMaster Carr. Its a bit more expensive than galvanized straight ducting but makes a smooth route and was fairly easy to install as one continuous piece. The duct is mounted high on the firewall because I don''t use the stock engine cooling system. Hey Chris - Is that another duct on the hood between your turn signal (used to be) and engine duct? |
ChrisFoley |
Jun 18 2011, 10:54 AM
Hey Chris - Is that another duct on the hood between your turn signal (used to be) and engine duct? The NACA duct is for a secondary brake cooling hose which goes through the inner fender and dumps air towards the caliper. The primary brake duct goes below the chassis and pushes air out through the vented rotor. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:12 AM |
