DJKnut |
Newbie ![]() Group: Members Posts: 11 Joined: 21-August 10 From: Bellingham, Washington Member No.: 12,085 Region Association: Pacific Northwest ![]() |
My car steers like a Mack truck, so I decided to start with new ball joints... I'm mostly working outside in the nice weather days... and up my way (NW Wash..) those are getting few and far between... However, I was able to get the first one replaced today... Disassembly was trial and error... lots of grunting and big hammers.. I used a wedge shaped chisel to separate the 'A' arm from the strut after removing the retaining pin.. that worked OK.... then after several aborted tries at pipe wrenching the lower retaining nut off, I resorted to popping it loose with drift and a big hammer, once I had it started, it came right off. Reassembly started with slipping the new ball joint into the strut and tapping the retaining pin in... which didn't go as far as it should have, so I pulled everything apart again, and found that the new replacement retaining pin had a rather sharp leading edge which dug into the ball joint shaft a bit and prevented it from properly seating... so after filing all the divots out, I put things back together with the old retaining pin, and it sucked in perfectly... It took a bit to get the new ball to move, but I eventually got it to line up with 'A' arm, and lowered the body jack down while supporting the 'A' arm from the underside with blocks, and then used the new retaining nut to finish snugging everything into place... Then the purpose made (and a bit expensive..!) socket was fitted to do the final torquing... It didn't have a real strong hold of the nut, and seamed like it would easily strip out the four lugs holding the nut, so I put a jack under the breaker bar and socket, and lifted until it supported the entire weight of the car, keeping everything tightly together, and then using a bar extension I tightened with everything I had... and the socket held tight... I suspect that I'm in the spec range (140 lbs +/-), but will double check tightness after I've run it a bit to let everything settle in.... Not too bad an afternoon project... now ... if we ever get another sunny day... I'll do the other side, and see if it cured the stiff steering issue. This just goes to show that driving isn't the only way to enjoy a 914... but it surely is something to look forward to!!! Cheers, Dave
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
Just used this as a guide, and I got it all apart! The drift was the answer, along with a sledge hammer, of course. I switched over to a dull cold chisel though, and that snapped it free.
Jim |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
What were the symptoms that made you decide to change the joints? I have a clunking when turning right and going over rough road. Also, if I push on the top of the tire and get it rocking, I can duplicate the sound. The PO put new KYb's intheback, but I don't know if the front inserts were changed or not. I don't really see any slop at the joints, what's to check next?
Joe |
jk76.914 |
What were the symptoms that made you decide to change the joints? I have a clunking when turning right and going over rough road. Also, if I push on the top of the tire and get it rocking, I can duplicate the sound. The PO put new KYb's intheback, but I don't know if the front inserts were changed or not. I don't really see any slop at the joints, what's to check next? Joe In my case, it's the struts actually. When I'd start out in the day, everything was fine. As the car warmed up, including the shocks, there'd be a vibration in the right front, which turned out to be the wheel going into some sort of vertical resonance because of a worn out shock. Also, I'm been meaning to do a 5 lug conversion, and I've had all the parts since 2003, including new ball joints, so I decided now's the time. When I got the strut out, I found I could grab an end in each hand and easily pump it in and out, so it certainly was worn out. My fronts were KYB, replace by the PO probably around 1980. Jim |
Lo-Fi Version | Time is now: 8th July 2025 - 02:48 PM |
