Coil wiring backwards, Makes no sense |
simonr |
Jun 19 2011, 02:40 PM
Member Group: Members Posts: 65 Joined: 11-July 10 From: Indianapolis Indiana Member No.: 11,925 Region Association: None |
I have a 1976 2.0. I purchased a Bosch blue coil . I know the green condensor wire goes to neg #1 on the coil. It wont start this way. When I move it to the positive post it starts. What is going on with this. Crossed wires somwhere else?
simonr |
Jun 19 2011, 03:27 PM
Green is on + . black and red on #12. Black on #15 thats the only way it will run I think that is backwards. It wont run the correct way
ArtechnikA |
Jun 19 2011, 03:35 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Green is on + . black and red on #12. Black on #15 thats the only way it will run I think that is backwards. It wont run the correct way Terminal 12? Where is that ? The 'black' wire - where does that go? Try leaving it off - it's probably the tach (should have a violet tracer...) Then - black and red to Terminal 15 (+) - first verify that this is your switched +12 And the points wire to Termina1 1 (-). Are there other wires connected to the distributor? Where do they go... The Kettering ignition system is dirt-simple, but it does have a few rules... |
Lo-Fi Version | Time is now: 8th June 2024 - 07:14 AM |
