First/Reverse Grind When Hot |
project-914 |
Jun 19 2011, 10:06 PM
Member Group: Members Posts: 181 Joined: 2-August 06 From: Oklahoma Member No.: 6,571 |
That's right
My car runs surprisingly smooth when first started, but when it warms up, first and reverse are a noisy chore I just finished redoing the clutch cable tube at the firewall by adding a small plate (don't worry, this car is by no means concours) I adjusted the cable and shift linkage accordingly (done it a thousand times) When in gear, the car starts lurching about an inch off of the floor (no pedal board) But, when it is hot, first and reverse grind a little bit and sometimes a lot. Could this be because my cable runs right by the header and the cable stretches due to heat? I feel like my pressure plate it grazing the clutch disc ever so slightly. Why is this only when the car has warmed up? My bushings are all ok (even on the fork pivot) Johnny |
rick 918-S |
Jun 20 2011, 08:17 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I know you said you tightened the cable but double check your clutch tube. I could be cracked free and flexing. Sometimes the cable adjustment cures it for a while. Maybe it's fine but if it continues it may be somethng to check.
Lo-Fi Version | Time is now: 10th June 2024 - 01:08 AM |
