I need a radiator for my SBC conversion, Ideas? Part numbers? |
pete |
Jun 21 2011, 10:52 AM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I need to purchase a radiator for my SBC conversion and am in need of some suggestions/part numbers. JEGS? Also, will need a over flow canister and hoses.
joefri187 |
Jun 21 2011, 02:55 PM
Newbie Group: Members Posts: 29 Joined: 1-November 05 From: Concord, CA Member No.: 5,047 Region Association: Northern California |
Here are a couple more pics...
The radiator is floating, not bolted directly to the frame as I've heard that bolting directly to the frame can cause the radiator to crack as there is a lot of expansion when hot... It sits on rubber mounts on the bottom and bolted on through rubber grommets along the top edge. And yes, it works great and everything stays cool!!! |
pete |
Jun 22 2011, 01:18 PM
Here are a couple more pics... The radiator is floating, not bolted directly to the frame as I've heard that bolting directly to the frame can cause the radiator to crack as there is a lot of expansion when hot... It sits on rubber mounts on the bottom and bolted on through rubber grommets along the top edge. And yes, it works great and everything stays cool!!! Thanks for the pics. Nice frame. I might go this route and make one out of aluminum square tube. Great idea to have it floating on rubber mounts. And I like this radiator. Is there plenty of room for the filler? When you purchase fans as you suggested do they come with some sort of controller? How is it wired? Thanks |
Lo-Fi Version | Time is now: 13th June 2024 - 03:48 AM |
