pete |
Member ![]() ![]() Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States ![]() |
I bought this starter off ebay. I bolted it to my trans and would like to see if it turns my SBC 350 over. How do I jump it? I don't want to start the engine. I just want to make sure it engages the flywheel and cranks the engine. I connected jumper cables to my car battery and connected the hot lead to the top of the starter under that black boot and touched steel with the neg lead. It spun the starter gear but didn't extend it. I connected a wire to the spade terminal under the starter and touched that with the hot lead and the neg to ground and it extended the gear but wouldn't spin it. I jumped the spade terminal on the starter to the ground I was using and touched both with the hot lead and it just spun, wouldn't engage. Any thoughts?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
hook up your jumper to the bottom large nut and then use a small alligator clip lead to energize the spade stud next to it.
The solenoid kicks the gear into the flywheel. You need to energize the motor via the solenoid. Rich |
Lo-Fi Version | Time is now: 16th June 2024 - 02:26 AM |
